Quick Steering
Old May 1, 2009 | 02:17 PM
Gman58's Avatar
Gman58
Default Quick Steering
I am trying to get info on the Quick Steering mod for a C1. From what I have found out it was used on track cars. Is it a easy install and does anyone have it on their car. Thanks Greg
Old May 1, 2009 | 02:26 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
i don't think you'll like it, they're hard enough to park as it is...
Bill
Old May 1, 2009 | 02:35 PM
Gman58's Avatar
Gman58
Default Always trying to learn
Bill
Thanks Bill
I am just curious about it. I don't want to install one. I am more interested in the design, install and performance aspect. Thanks Greg
Old May 1, 2009 | 02:52 PM
DZAUTO's Avatar
DZAUTO
2026 Corvette of the Year Finalist - Modified
2025 c1 of the Year - Modified Winner
2024 C1 of the Year Finalist - Modified
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
I have one on the 56. And I have 225/75R15 inflated to 32-33psi on 15x6 steel wheels up front.
It is an ultra simple bolt-on, and when installed, an alignment will have to be done.
To install the adapter, the L&R tierods are seperated from the center steering arm, the adapter is installed onto the steering arm and the tierods are attached to the adapter. The fast steering adapter simply increases the length of the center steering arm, which of course, as already mentioned, will also increase steering effort at a stop or very low speeds.
I've had the adapter on the 56 since about 1974, I'm 66 now----------------and I ain't takin' it off!
Most likely, for you wennies who are spoiled by pwr steering, you won't like it in town.
The fast steering adapters are sold by the Vette vendors (CC, Paragon, etc) for about $125.
Tom Parsons
Old May 1, 2009 | 03:06 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
Tom Parsons
the fast steering adapter is a U-bolt and a piece of plate; you can make your own for about $10.
Bill
Old May 1, 2009 | 04:01 PM
Gman58's Avatar
Gman58
Default Good Info
Tom Parsons
Thanks Tom
Thats the info I was looking for. Sounds like you like the modification. Thanks again Greg
Old May 1, 2009 | 04:09 PM
john neas's Avatar
john neas
Tom Parsons
I believe that Frank Burrell designed the fast steering adapter. Frank was a graduate engineer and worked his way through college working in a salvage yard. According to a friend of his, he never left the salvage yard. He was a key engineer and lead mechanic on the 56 Sebring program. I have some of his initial sketches for some of his improvisions plus the final GM blueprints. I also have a T-10 overdrive transmission he built. I have the adapter on several cars. The one that steers the hardest is the Bob McLean SR-2, it has a 15" wooden steering wheel. Tom has no problem though as he and Janet had significant wheel spin in all four gears!!!
Regards
Old May 1, 2009 | 07:10 PM
DZAUTO's Avatar
DZAUTO
Here is the fast steering adapter installed on my 56.
Tom Parsons
Old May 1, 2009 | 08:40 PM
Gman58's Avatar
Gman58
Default Great pictures
Tom Parsons
Tom thanks for posting the pictures I just could not visualize what it would look like. Thanks again. Greg
To Quick Steering
