Clock Rebuilder
Old May 2, 2009 | 04:05 PM
67vetteal's Avatar
67vetteal
Default Clock Rebuilder
Doing over my entire Dash area, Radio Rebuild, New Radio Speaker, Cluster Refurbish, Light Bulbs Etc.. My Clock looks very poor. I'd like some recommendations for a rebuilder. Anyone have a Driver Quality they will sell me? Thanks, Al W.
Old May 2, 2009 | 04:26 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Al, I send mine to Corvette Clocks by Roger. That is when I am having everything else repaired and re-silkscreened. It all goes in one box. They come back spot on. You can buy the outer bezel and I can help you in getting yours working again, and it really isn't that hard but is a bit tedious when staking the studs that secure the outer bezel to the clock housing. I am not at work right now and would have to check if the needle and face of the clock are replaceable. Also remember that if the original type of clock is reatored and not replaced with a quartz movement, It will require occasional re-setting of the time and service in the future due to its design. I myself like the clicking sound that it makes but the quartz movement design does not make any noise but does keep correct time, or at least those that I have installed and gotten feedback from my customers.
Old May 2, 2009 | 04:38 PM
rogers 64's Avatar
rogers 64
I used Roger also and the turn around time was quick and the restoration was excellent. Would use him again anytime...
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
got a clock rebuilt by him and 2 years later with less then 1000 miles on the car the clock had to be rebuilt by someone else because it not work correctly. and it was quartz
Old May 2, 2009 | 05:40 PM
67vetteal's Avatar
67vetteal
I like the clicking sound also. Years back we used to just open them up, clean the points and they would run for a year or so. Today when we put our cars in the garage we use the Battery Switch to shut off everything, even the clock. So, they last much longer after being cleaned up without the Quartz. Still trying to figure this out. Al W.
Old May 2, 2009 | 07:10 PM
Army Vette's Avatar
Army Vette
What might the price be for a rebuild from Roger?
My clock works when a pull a Fonzi and smack the top of the dash when the car is running. Maybe i just need to clean it out, gotta get in that dash.
Old May 2, 2009 | 07:22 PM
JohnZ's Avatar
JohnZ
When mine died in 2002, I pulled it out and it had a "Clocks by Roger" sticker on the back; sent it to Brian at CSoM, and it's still tickin'.
Old May 2, 2009 | 08:09 PM
shemp's Avatar
shemp
I presume that is corvette specialties of maryland.
Shemp
Old May 2, 2009 | 08:35 PM
PBChase's Avatar
PBChase
D&M Restoration. They have done my clock, radio, headlight motors, and speedo/tach gauges. Great work and very reliable!
Old May 2, 2009 | 09:42 PM
Nowhere Man
we send ours to his BIL who use to work for him who made them famous for there work
Old May 2, 2009 | 09:52 PM
RoadKing96's Avatar
RoadKing96
From: Holly Springs, Nort Cackalacky / Jupiter, Florida
A good friend and myself have both used Bill for both our Clocks and our complete Cluster restorations, and to be honest, we could not be happier. Check out my results here....I'll soon be posting all of it re-installed.
My Cluster, Gauges and Clock
Excellent work, and Quality, with clocks either Quartz or original mechanical movements (your choice) and prices are competitive, in my opinion. Personally I too like the sound of the mechanical.....
harrisonspeedometer
(561)676-3099
Good Luck,
RK
To Clock Rebuilder
