Window installation question
first of all it is a 63 coupe. Eventually, the window was pretty much stuck in place. I took the inspection plate off and noticed that my upper regulator guide rail was bent. It was difficult to get out but I eventually got it out. It is bent and I need a new one as I don't think I can beat it back straight enough. The regulator mechanism will now roll down.
Looking at the bottom of the window where it goes into the channel of the ventilator assembly (front window channel) and all looks good. It seems properly seated.
Looking at the rear, I notice the bracket of the window sash (that part the window is mounted in) is inside the rear run assembly (rear channel).( The bracket I am talking about is actually that bracket that bolts the upper regulator guide rail to the window sash.) It looks like it is binding. To me, it does not look like that bracket should be inside the rear run assembly.
Anyone know whether the window sash rear bracket is supposed to be inside the channel of the rear run assembly (rear glass channel)?
The glass needs to be removed and reinstalled into its channel, so that the bracket is forward of the rear window fuzzy.
Somewhere around here is a great illustrated tutorial of how to replace a coupe side window. Dave Z. author. It's not too hard, just a few tricks to the sequence of operations.
