Dwell......
Agree with both Donald and Dan....although the correct Accel Part Number you want is #8104 (and not #8140). I would also "double-check" your new dwell meter with a feeler gage on the (new) points to be sure the meter is functioning correctly.
I remember many years ago buying a new meter and setting the dwell on my friends car. Car would not start. We found that the points did not close, even though the meter indicated the correct dwell value.
I would confirm that your new meter is reading correctly before trusting it completely and making distributor adjustments.Larry
EDIT: Just in case you don't know/remember, adjusting the dwell back from 40 to 30 degrees will increase/affect your initial timing.....so be sure to recheck your initial timing after setting the dwell to the correct value.
I have always used the Accel points. They are a heavier duty set and really allow the higher RPM's without the point bounce. A setting of 30 is perfect.
I personally use the B-W 112HP points for customers' dist, but the Accel are fine.
When I was running points (everything I have now is PerTronix, and I ain't switching back!!), I always tried to set single points at 31deg and dual points at 34 exactly.
Tom Parsons
In other words, if you like buzzing through the gears, use the max. dwell (32 degrees for single point dist.), and if you are not concerned with high rpm operation, then use the a narrower setting (28 degrees) for longer point life.
One blessing of an electronic replacement (like what Tom uses), is that the design engineer can specify an electronic "switch" (semiconductor) that can handle more heat, which then can allow for more dwell and coil saturation time. However, then the coil itself comes into play. Coils have heat issues too, and an electronic switch adds a small amount of resistance to the circuit (decreasing output), so it is always best to change to the electronic switch's manufacturer's recommended coil! Of course the main downside to an electronic set of points is unknown reliability, and the difficulty in diagnostics and repair. And don't get me started on MSD units as to lack of reliability!
I have had 3 different dwell meters at the same time, and all 3 read a different reading! That includes my Sun Dist. Machine which was the farthest "off"! So like stated above, check the gap with a feeler gauge on a new set of points to determine the right "setting" to dwell reading. Don't just take a dwell reading as gospel, until you know you can trust the meter.
And as stated above, always reset ignition timing after changing the dwell!
Plasticman
I agree with the point recommendations. I am running Accel.
I set mine at 29 degrees, as they usually "seat in" very quickly, and go to 30.
Always lube points when installing, both new and used, but lube sparingly. Too much will get on the contacts, and mess things up.
I apply lube sparingly to the cam, and spread it evenly all the way around. Do not leave any globs or excess.
A gap gauge should only be used with new points, or used points that have been filed flat.
we used to eyeball the point gap and check on a sun scope after the tune up (it was fun, i got pretty good).
MOPARS and fords were a pain, because if the dwell was off, you had to pull the cap and rotor off and adjust dwell with a screwdriver between the points plate and the dist plate.
GM and vettes had the best design, you would just open the little window in the cap and adjust the point dwell with a 1/8 allen with the engine idleing and watch the dwell reading on the sun scope.
i always set dwell at 28 degrees in single points (because the nylon piece that rubs on the dist. shaft cam as it wears will bring the dwell closer to 32 degrees. (the specs were 28-32 dwell)
as the degrees dwell increases, the timing retards.
dual points were a different matter. dual point dists. have 2 sets of of points that are slightly offset on the point plate. i would set each set of points at 28 degrees, giving a combined dwell of 34-36 degrees dwell and let them wear. while delco made a dual window cap to adjust the dual points. they were obsolete by the 70s, so we would just put a little piece of match book cover between the points under the window and set the other points at 28 degrees. then use the 1/8 allen to adjust the second set of points to 34 degrees. then set the timing.
as tom says, now i just forget all old skool noncince and run pertronix.
I can't remember!
The points installations I remember best (or worst) were the Ford Y-blocks (272, 292, 312 engines) with the distributor mounted way in the rear, and NO allen wrench adjustment screw. Just a screwdriver slot......lots of trial and error....since tightening the hold down screws always affected the gap/dwell by a few thousands/degrees. And if you weren't careful, you could drop/lose those tiny mounting screws.
Those were the days. Especially in the summer on a hot/warm engine.
Larry
Bob
Larry
The Ford 289 engine series (221, 260, 289, 302) was a very nice setup. And they ran well too. The fender mounted solenoid was a BIG help for just about any kind of engine work.Larry
