Camshaft selection help..........
http://www.compperformancegroupstore...Category_Code=
This is the cam I currently have in the alum 427 and it is just too much for the street: http://www.compperformancegroupstore...Category_Code=
Has anyone had any experience with either of the first two cams? This car is just a street cruiser, I want plenty of low end torque and a nice rumble thru Stahl headers that dump into 3 inch side pipes with spiral tube inserts. Gearing is currently a Richmond 5 speed with 3.70 rear, but will probably change to a 3.08 rear.
Thanks for your input.
Rex
I have a mild street cam in my Kirkham and you can't believe how much crap I take from my buddies. But my car has the best street manners and I'm always ready to go on a 200 mile trip, while my "buds" aren't.
You've got a big block, let the inches work for you.
Just my opinion.
the car will run fabulous..
you can go 10k between checking valves,
it will make plenty of vaccuum, and have great street manners..
those XR cams... have a ton of valve train noise because of the aggressive lobes.
i'm sure the race guys will chime in with ideas, but for a street cruiser, you can't beat the factory HiPo shafts.
A
Other things like a dual plane intake and not to big a carb make a big difference for a good but peppy street cruiser
BTW.........A word to the wise concerning the 850 DP Holley.......... in reality it flows up between 950 -1000 and that is why so many people who buy one end up with real dogs in the lower rpm range. On your motor a well tuned 750 or at the most an 800 would IMO deliver the best street manners for you.
Just my .02
Doug
Unless you've heard recent news about Schubeck solid roller lifters, I;d stay away from solid roller cams, too.
To tell ya the truth, I'm with aaron. I had the L72 cam in my 65 with oval port heads and that was just about the best overall street motor I ever had.
Keep your comments coming.................I've got to get this thing ready for the upcoming Hot Rod Power Tour.
Thanks,
Rex
I was running a 588 lift Comp cam in a 454, and it was worse than the ZL1 cam I had in my L88. You needed 1400 rpm at idle in neutral to have enough idle in gear, with a 4000 convertor. I switched to Rhoads lifters, and idle was 1000 in neutral, 800 in gear and 700 with the AC on. Bottom end and midrange improved so much that the car blew off the 10x29 D5 Goodyear slicks that had been sufficient up to that time. Went to a softer compound 10.5x28 Michey Thompson. Engine would pull hard to 7200, but I usually shifted at 6900. My 4100 lb Monte Carlo with 4.10 gear went 11.80 @ 114.12.
I currently run 2 454 Montes with 555/576 Elgin cam with 112 centerline. and Rhoads lifters. One is auto with 3000 convertor, big port 291 heads 850 holley and 4.10 gear. The other is 4 speed, oval port open chamber heads with 2.25/1.88 valves 850 holley and 3.73 gear. Both have 71 LS6 design 9to1 pistons, the auto has forged, the stick has hyperutectic. The gearbox car is faster.
Both cars idle like a stock LS6, when warm, without a lot of lope. I shift around 6700. To me the only drawback is they sound like solid lifters, and I like to walk softly, but carry a big stick, so I would prefer quite lifters.
Other than that I am very happy with them.
Btw, it is not hydraulic lifters that limit rpm, but cam profile and valve springs. Valve float is caused by the springs giving up. The hydraulic lifters then take up the slack left by the springs, and take time to bleed back down, so they get the blame. I lash my hydraulics at 1/8 turn after 0 lash, which helps prevent pump up, and can add several hundred rpm to a hydraulic cam. Been doing this for 30 years without a problem.
For example, GM lists their specs as follows:
Camshaft lift (in): .527 intake / .544 exhaust
Camshaft duration (@.050 in): 224 intake / 234 exhaust
Duration is listed @ .050 inch
For a "seemingly" similar cam, Comp Cams lists the following
Camshaft lift (in): .521 intake / .540 exhaust
Camshaft duration - advertised duration 288 intake / 294 exhaust
duration @ .050 inch 236 intake / 242 exhaust
The latter cam (Comp) is the one I have in the engine now and it is too wild for the street. I am considering buying a new cam from GM (the first one listed above) that is the std cam in the 502-502 crate engines. However, on paper, they look almost identical.
I need to enroll in "Cams 101". Anybody teaching?
Thanks,
Rex
Is that cam you have a flat tappet? If so, see my previous post.
Thanks,
Rex
Thanks,
Rex
the 110 LSA will have much better street manners than the 106 IMHO.
the tighter LSA will make the engine more peaky, the wider makes it broader, and is generally the more acceptable route for a street cam.
I still think that the L72 (while it is a solid cam) is your best bet.
hands down..
i can almost guarantee that while there will be lash, it will still be quieter than the rhodes variable lifters, or the XE series hydraullic cams that comp offers. those suckers are just noisy, and if you are going with a flat tappet, the XE stuff is much harder on the parts than the OE solid cam will be.
you'll be able to go 10-15k without worring about the valves and the motor will run forever.
it is very gentle on closing the valve also so you won't need a valve job in 30k miles either.
I just recently drove an L72 in a camaro, and it was the best of everything... had a nice lopey idle, but not a race idle... (sounded like a stock Hi-Po camshaft) and it made plenty of low end, and pulled to 6500 rpm... everything you'd want from a great street car.
Good luck
Aaron
Thanks,
Rex
Rex
I am actually getting ready to install the second cam you have there in my 427, the XE 282 HR. I've gone through 2 of their XE 284 hyd flats already and after this rebuild, I've decided to try their hyd roller this time. I was going to back down to their XE 272 hyd flat, since the 284 was pretty extreme on the street. But after some thinking, I decided to spend some more $ and go the hyd roller this time. Also, I wiped a lobe really bad on a flat tappet the first go around, so I am also hoping that the hyd roller provides more durable this time around.
The engine builder should have mine this week, and it will be a couple more weeks until she's running again. Not sure what your time frame is, but I am sure I'll get some video clips of it in a few weeks.
Later,
Rob
Here are the two GM cams I am considering. Please review the specs and let me know your thoughts, or better yet, if you have used either and your opinions. Please note the difference in durations and lobe centerlines. As I stated earlier, I am looking for a cam for my 427 ZL-1 with 9.5 : 1 compression, oval port GM alum heads, GM dual plane intake, 750 Holley dp carb. Engine needs to be capable of 900 - 1000 RPM idle, ample vacuum for power brakes, good throaty sound, and good power from idle to 5000 - 5500 RPM, dependable and streetable. I know, I'm asking for a lot.
Thanks,
Rex
This is the one for the 502-502 engine:
Part #12366543
Steel hydraulic roller
I: 224 E: 234
I: .527 E: .544
Lobe centerline 110
For 502/502 special engine. Must use distributor gear P/N 10456413.
This one is used in the 454 & 502 HO and teh new Anniversary 427 ZL-1 engines:
Part #24502611
I: 211 E: 230
I: .510 E: .540
Lobe centerline 112
For 454 and 502 HO engines. Must use distributor gear P/N 10456413.
427 SB, BTW
Can't get much more street friendly than that, and it has an average Tq over that RPM range greater than an L-88.
Doug
