Accelerator pump tuning
Old May 26, 2009 | 02:05 PM
R6T7's Avatar
R6T7
Default Accelerator pump tuning
I'm trying to eliminate an off-idle hesitation on my '67 327/300HP engine - it idles smoothly at 600 to 700RPM, runs great at speed, but has just a bit of stumble when accelerating from a stop. The engine has been rebuilt to stock specs (as close as possible), runs cool, lots of power, etc, so I don't think I have a timing issue. I've adjusted the accelerator pump per the Holley procedure, and checked the .015 clearance at WOT.
I think I need to change the accelerator pump cam to eliminate this problem, and it would be nice to know what cam would have been used for this engine? The carb is a list 3814A which is correct for a 300HP engine with K19.
I have the same problem in my '66 350HP K19 car, so I'm hoping to kill two birds with one stone.
Does anyone know what pump cams were used in what engines?
Bob
Old May 26, 2009 | 02:49 PM
JohnZ's Avatar
JohnZ
Mine has a red cam in the #1 hole, runs great.
Old May 26, 2009 | 02:50 PM
w1ctc's Avatar
w1ctc
I have the same problem. It has followed me though 2 carbs, 2 different type electronic ignitions, new heads, with or without vacuum advance or PCV, numerous timing setups and every possible setup of the accelerator pump. The momentary hesitation at throttle tip in remains. I wonder if it's the current gas or some other odd thing that we are missing.
Old May 26, 2009 | 02:55 PM
midyearvette's Avatar
midyearvette
no it's more than likely the pump adjustment or try a different cam or the second hole with the same cam turned around,,,,,also be sure the squirters are shooting into the boosters, it shouldnt make a difference but i have seen where it will....loosen the screw and adjust the nozzles and then re tighten...
Old May 26, 2009 | 03:28 PM
65 vette dude's Avatar
65 vette dude
I have had the same problem for a year on my 2818 Holley. I worked on it for 2 days straight. Here's what I did to finally get rid of it. I had a .025 squirter,and I upped it to a .028. Helped some,but it did not get rid of it all. Next I bought the Holley cam kit. The green cam,in the #1 hole got rid of it completely. When I changed to that cam,I noticed that the spring was no longer touching the accelerator arm,which of course would cause a huge dead spot. Extended the spring down until it was solid against the lever,and made sure I had the .010 to .015 clearance,between the bottom of the spring and the pump lever,at wide open throttle. If you go to You Tube and do a search on" Holley Accelerator Pump",there is a very good video on the subject.
Old May 26, 2009 | 08:00 PM
R6T7's Avatar
R6T7
Well, I have tried a red cam in the #1 hole - it is better, but the hesitation is still there. I ordered a complete cam kit - then I can try some other options. I've viewed the Holley video - it's very helpful. The squirter in the carb is a .028 which should work for this engine.
Bob
Old May 27, 2009 | 07:36 PM
PAmotorman's Avatar
PAmotorman
if the throttle arm on the shaft has come loose and was not put back on in the correct position you will have this problem. a lot of holleys with brass throttle shafts have had this problem.
Old May 29, 2009 | 03:45 PM
w1ctc's Avatar
w1ctc
Try this. Turn the idle needle screws out (CCW) one (or more) turn from where you have it. (should be around 1.5 turns out normally) The engine may run a little rough and see if the hesitation goes away. If it does, adjust the idle screws for a compromise of smooth running and no hesitation.
The other thing I found was the that if the secondary throttle stop screw holds the secondary plates open too far, it will cause the problem. No combination of cams was able to solve the problem till I hit on this. The normal adjustment for the throttle stop screw is 1 to 1.5 turns from seated. Carb needs to off the car to adjust unless the screw is replaced with an allen head set screw.
Old May 29, 2009 | 04:05 PM
ghostrider20's Avatar
ghostrider20
Sometimes the cam lever can get bent when bubba adjusted it too tight. Select a cam, white or pink (good start) and make sure the cam lever is riding on the cam. Next adjust the spring bolt. You should have a shot/pee at the slightest throttle movement. If the cam lever is bent (will only be a slight bend to cause a problem) you can try and bend it back, or get a new one.
Mark
Old May 29, 2009 | 04:11 PM
JohnZ's Avatar
JohnZ
The Holley spec for that secondary throttle stop adjustment is 1/2-turn open from seated.
Old May 29, 2009 | 04:30 PM
R6T7's Avatar
R6T7
Thanks, guys -
I hadn't thought about the secondary throttle plate adjustment, but that could well be part of the problem. But I would think that idle would be affected if the secondary plates were to far open?
Bob
Old May 29, 2009 | 06:27 PM
DSR's Avatar
DSR
Do you have a vacuum secondary carb? If so try a heavier spring so the secondaries open later.
Dave
Old May 29, 2009 | 07:09 PM
w1ctc's Avatar
w1ctc
Originally Posted by R6T7
Thanks, guys -
Bob
Only if its open so far that it won't idle down with the primary adjustment.
Your right JohnZ, 1/2 turn from closed.
Old Jun 2, 2009 | 08:02 PM
R6T7's Avatar
R6T7
Do you need to use a dial indicator to determine when the throttle plate is closed - or just eyeball it?
Bob
Old Jun 3, 2009 | 02:00 PM
JohnZ's Avatar
JohnZ
Bob
Just eyeball it - back out the screw, let the plates close, turn the screw in until it contacts, and give it another 1/2-turn.
Old Jun 3, 2009 | 04:23 PM
R6T7's Avatar
R6T7
Thanks, John -
When these cars were new, was there a difference in driveability between the cars equipped with K19 and those that weren't? I remember in later years the California cars had some real issues, but since I did not own a new Corvette in 1967, I have no reference point. Of course then there's the memory issue. . .
Bob
Old Jun 3, 2009 | 05:19 PM
Jims66's Avatar
Jims66
Make sure the dwell on your points is within spec (28-32). Simple 2 minute task. My dwell setting turned out to be my "carb fuel" issue when stumbling from start was happening to me. Remember...... 90% of fuel problems are electrical !!
To Accelerator pump tuning
Old Jun 3, 2009 | 07:43 PM
stall's Avatar
stall
I had a severe stumble on acceleration and found it was in the idle circuit as listed above but i had to turn the sv=crews in and acheive the highest possible vacumn reading (advice from the forum crew) It worked and the stumble is gone, the 64 goes like stink now.
Good Luck
Old Jun 5, 2009 | 09:29 AM
PAmotorman's Avatar
PAmotorman
if the idle transfer slot is not exposed at idle you will have this hesitation because the idle transfer covers the time it takes for the fuel to reach the bottom of the carb from the pump shooters
Old Jun 9, 2009 | 10:56 AM
bluester's Avatar
bluester
Default accel pump
Mark
Make sure that you get some pump squirt with the minutest movement of the throttle, absolutely no free play. If there is no free play but the throttle has to move more before it squirts, it may be the pump check weight leaking. If the check leaks, the fuel goes back down the passage and has to "travel" before it gets to the nozzzle. Remove the pump squirter and flip the carb over to get the check out, yours should be a needle pointed weight (some apps. use a check ball). Polish it up a little, drop it back in and give it a tap with a small hammer & punch to seat it, then flip the carb upside down, drop it out and then drop it back in (you don't want to leave it "seated").
