John Z
Old May 30, 2009 | 12:12 PM
drlou's Avatar
drlou
Default John Z
John, do you think a Champion c63cx would be too hot a plug to run on the street? I will be using GT100 unleaded gas with a dose of VP110. 427/435 w/hydraulic roller. 11.5:1. Thanks
Old May 30, 2009 | 03:39 PM
JohnZ's Avatar
JohnZ
I'm not familiar with that plug; stock L-71's run fine with AC R45XLS plugs. PAMotorman may have a suggestion.
Old May 30, 2009 | 04:24 PM
Ironcross's Avatar
Ironcross
The Champion 63 is a warmer plug, but as John suggested the R45XLS heat range is good for most BB engines including the L88`s. You could also use 44`s as long as its a tight sealing engine with correctly jetted carburetors so they wont fuel foul from idling....All that's necessary is to use what John recommended for your best performance...
Old May 30, 2009 | 09:08 PM
drlou's Avatar
drlou
Thanks guys, I had a set of these c63cx's laying around and I wanted to test fire the motor. I can't seem to find a good cross reference from AC to Champion. I guess I'll order up a set of c61cx's for the actual driving.
Old May 31, 2009 | 09:48 AM
Powershift's Avatar
Powershift
JohnZ's recommendation for AC R45XLS spark plugs crosses over to Champion RN14YC.
Larry
To John Z
