Headers vs. Manifolds
Old Jun 2, 2009 | 12:19 AM
vtwinspring's Avatar
vtwinspring
Default Headers vs. Manifolds
I hate the sound of exhasut leaks and it seems with headers I am always going to have that problem. How much HP will I lose by switching back to manifolds. What is the noise level difference?
I am running a 350 sb with a mild cam.
Old Jun 2, 2009 | 01:46 AM
narlee's Avatar
narlee
Are they full length or shortys? If they're shorties and you use 2 1/2 ramhorns not much at all, especially with a mild cam.
Old Jun 2, 2009 | 01:48 AM
ghostrider20's Avatar
ghostrider20
Not enough to notice.
Old Jun 2, 2009 | 09:04 AM
mashinter's Avatar
mashinter
Car Craft did a dyno study on a truck 350. Cat-back increased power. Headers did nothing.
Old Jun 2, 2009 | 10:07 AM
Kensmith's Avatar
Kensmith
I have the original 2 1/2" manifolds on my small block 383 stroker and 2 3/4" Allen's sidepipes. I ported the manifold to match the exhaust ports on my Dart Pro 1 aluminum heads. Sounds great and runs better than it sounds.
Old Jun 2, 2009 | 11:12 AM
oldandtired's Avatar
oldandtired
Are they leaking at the head or at the collector? The use of embossed copper gaskets will fix your head to header leak. I always convert my three bolt flange collector to the ball flange kit. Never had luck sealing the darned three bolt deal.
Old Jun 2, 2009 | 12:42 PM
toddalin's Avatar
toddalin
Definitely a step backwards in the performance department both for power and fuel economy.
Use better header bolts that you can get a wrench on/Allen key in.
Old Jun 2, 2009 | 02:02 PM
66since71's Avatar
66since71
From the team that did the ZZ series engines at the old GM: They showed a "significant" improvement in power with 1 3/4 x 28" primary tube headers. (I think those dimensions are right, but it may have been 26" long.)
Harry
To Headers vs. Manifolds
