Brake problem! Help!!!
My mistake. I was thinkng you were working on a '67. Don't change the rotors.
Check your Pm's.
If you left your '66 booster-to-master pushrod in place when you changed to a '67 master cylinder, it's the standard "short" pushrod used for power brake master cylinders with the "shallow" hole in the rear piston, so it's not able to depress the '67 "deep hole" rear piston far enough to provide adequate braking action.
I get the pull from the right rear. I also get a good stream of fluid from the bleeders. I did not at first, but now I do after changing the rubber hoses. The right rear tire is the only one that will skid. since I am getting that on the right rear, then maybe the pushrod is depressing the M/C far enough. Now, maybe i do have a problem with the pads or rotors. They appear to be good, but maybe fluid got on them while doing all this work to the car. I did have air in the lines, but remember I first changed the master cylinder, then the hoses, then the calipers. It took a while to bleed them, but I have a good hard pedal. The pedal is always good and firm, but just don't stop the car the harder I push them at higher speeds. At lower speeds, the car does stop ok. They are definitely better since I changed the calipers and hoses, but still not satisfactory.
In my opinion, rotor runout is a red herring in your troubleshooting.
After all you've changed, I'd start to let my mind think about the truly oddball stuff..... for example is there any way you could have reversed the front and rear connections at the proportioning valve? That would give you tremendous rear braking and limited front braking. On the left rear, the corner that doesn't lock up, is there grease getting on the rotor or pad surfaces? That kind of thing...
Jim
Jim
Too, there isn't anything about the master cylinder or its mechanical linkage that could possibly affect a single wheel, like the RR for example.
The new pads you will be trying might help. But if they do, it'd be good to ask "why?". Why are they needed? Are the old pads on 3 out of 4 calipers glazed? If so, why?
In any event, good luck with that experiment.
Jim
This seems to me like another red herring. You have a good, firm pedal at normal height, yes? If so, you are depressing the MC piston adequately and the length of the rod isn't an issue.
Jim
You have come to all the same conclusions I have.
Front/rear brake bias is handled by different size pistons in the calipers. Same principle as the drums.
Jim
I went over to Danny's last night to help with the brake diagnosis.
First, JohnZ hits another home run with the length of the master cylinder pushrod issue. The old master cylinder (which was some sort of generic replacement, with line openings on both sides of the master cylinder) had a very short opening into the piston bore.
The replacement 1967 to 1970 something master cylinder had a much longer (more depth) opening into the piston bore. We replaced the short 66 pushrod with the longer 67 pushrod.
We also replaced all of the brake pads. Calipers had previously been replaced. One of the pads had very minor fluid contamination on a small part of the surface. Other than that we didn't see anything wrong.
Took the car for a ride. It now seems to stop straight, with no pulling to the right as previously indicated.
However, the car still doesn't seem to have the stopping power it should have. Danny hit the brake pedal hard from 45 - 50 mph, and the car stopped straight, but really didn't slow down like it should have.
I drove the car and the pedal felt solid, with almost no free travel. Danny re-adjusted the rod under the dash to add back in some of the free travel, but is still doesn't feel quite right.
Also, there is a strange clicking noise under the dash (or perhaps from the power booster) when the brake pedal is pushed. We unbolted the master cylinder from the power booster, and the clicking noise is still there. It is like you push the pedal, it travels for a bit, then something "pops" (like something mechanical was binding) and the pedal continues.
We re-bled the brakes (very little, but some air in a couple of the calipers), but that didn't help much, car still doesn't stop like it should. It is almost like the brakes don't have enough clamping force.
Rotors look fine, no glazing or grooves, but they were not resurfaced.
Danny says the car stopped much faster before the master cylinder replacement. It was also pulling to the right then.
He still has the old master cylinder (with line openings on both sides, anybody know what this is?). I suppose we could put it back on.
New master cylinder was bench bled while on the car. It was bolted up to the power booster, the bleeder hoses / fittings were connected, and it was bench bled by depressing the pedal until all of the air was out. Then the lines were connected and the entire system was bled.
All of the brake hoses were also replaced.
OK, any ideas? Do we have a mismatch between a 66 power booster and a 67 and later master cylinder? FYI: The bore size of the new 67 and later master cylinder measured at 1.118 with a vernier caliper (1 1/8, I assume, which is what a non power booster master cylinder should be). Old master cylinder measured 1.024 (I think) bore size.
Where do we go from here?
Reminder, car is a 1966, with power brakes, a 67 and later style master cylinder, no proportioning valve. How is proportioning handled in that situation? Line size? Both front and rear lines coming from the master cylinder looked to be the same size to me.
Calipers are all in their correct locations.
Danny, jump in here and add / correct anything I may have wrong.
Using the numbers you measured, the hydraulic line pressure with the new MC will be about 17% less for a given pedal effort.
If the two master cylinders really are 1.0 and 1.125, the reduction in line pressure will be about 21%.
You'd notice that much of a change.
Jim
Jim
Hard for me to say that pedal pressure is different, since I drove the car for the first time last night, and the new (1 1/8) master cylinder was on it them.
Are you suggesting that we should go to a 1 inch bore master cylinder?
Danny still has the old master cylinder, and it looks to be in nice shape.
The longer rod is straight, with a flat surface on the back end, and the rounded surface on the front end.
Is this an issue?
Jim is correct. The smaller bore master cylinder will generate more line pressure with the same pedal effort. I don't know about power brakes but if you use a larger master cylinder with manual brakes, you'll notice a higher, harder pedal than if you use a smaller bore master cylinder. There is quite a difference in pedal effort for the same deceleration rate. At least with manual brakes.
The '66 manual brake cylinder is single piston, 1" bore.
