4 speed Question
George,
1. The easiest fix, make sure you have adjusted the clutch lever properly. Most will have the locking nuts on the interior clutch rod near the end. If you have adjusted all the way to the end and it won't disengage, you have other issues.
2. Wrong throwout bearing. It happens. There is a long and a short throwout bearing depending on the bellhousing you have. If you have a blow-proof or scattershield, you need to get a throwout bearing that works with it. Yours may be too short.
3. Wrong clutch fork, wrong clutch rod. Surprising how many cars out there are using the wrong parts because believe it or not, many cars have been modified with lots of non-original parts over the years.
4. Clutch problem. Did this just happen? If so, the clutch disc broke. The damper springs could have popped out and are now wedged between disc and pressure plate.
if this happened after the car sat all winter, then the disc is rusted to the flywheel. Very common. Hopefully you have the car pointed in a way to go for a drive and not hit anything, so put it in gear for the direction you want to go, start the engine and hang on! Avoid stop signs and stop lights and if you push in the clutch and brake you can break the disc loose. Sometimes you might have to give some gas while braking.
Also, can you adjust the clutch where there is almost no freeplay at all and have it release? If so, you can do so and drive the car around a little and then re-adjust the clutch. Sometimes you have to wear off all the "Fuzz" and other stuff left over from making the disc and get it seated in. After that, you may fine the adjustment will be where it is supposed to be.
Is the fork is hitting the firewall and not allowing the clutch to fully release? You can install an adjustable ball stud to allow for a little more adjustment without completely removing the transmission.
Take a close look at everything before you go to all the work of removing the transmission and getting the clutch apart.
Just some thoughts.
Good Luck,
Chris, CWPASADENA
CW The fork isn't hitting the firewall. As much as I hate the idea of removing the trans. I see not other option. I'm sure now the problem is in the bellhousing just not sure what it may be.
If you had mentioned it sat for a year on a fresh flywheel, you'd have had your answer. It rusted together, just like many do in the winter.
It sounds more exciting in print than it really is. The trick is getting out of the garage and onto the street, as you can' t push in the clutch and stop moving.
Usually the blip of the throttle a couple of times with the clutch pushed in, or a couple of taps of the brake will break it loose. At least a big block will.
