Ok, I have Vintage A/C and a Holley Idle solenoid that works fine with 12 Volts. Problem is I can't get the 12 volts from either the compressor or the blower switch that turns the A/C system on. Both only are putting out 10 volts at idle. I haven't checked any other electrical parts. Any ideas? I am a total idiot when it comes to electrical. But I can check voltage.
Ken. If you check your alternator output it should be about 13.8 to 14.2 volts. This is basically the voltage being applied to your electrical system.
The voltage you read at the compressor and blower switch is a function of an voltage drop through the wiring, connectors and contacts. Each one of those components has resistance and the voltage drop is a function of the amount of current flowing through all the components.
If 10 volts is not sufficienct at the input to the solenioid then you will need to trace the wiring back and find where the voltage drops are occuring. You may find one wire, connector or switch contributing a to a significant portion of the drop. I cannot recall how much work you have done to the wiring system in your car but if a lot of it is original it would be easy to drop 3 volts along the way. You may find 10 volts is sufficient for your solenoid and that it is within the accepted voltage range for proper function.
It would appear that your alternator is not putting out sufficient voltage/current for you "system" at idle (too much load for the alternator), or you have a significant voltage drop.
You will need to verify that if you only have 10 volts at the compressor or blower, then you only have 10 volts at the battery and alternator (not good), so follow NeverL8's directions first. These voltage readings all need to be done while the blower is operating at full speed and the compressor clutch powered "on" (with the engine running at idle).
The other possible problem is the wire gauge is not sufficient to carry the load current for those items (compressor and blower). I can understand the blower drawing a high load and seeing a significant voltage drop, but the compressor wire is only engaging the compressor clutch and should not be a high draw. The compressor wire would be the normal location to connect the idle speed solenoid.
Plasticman
But take the various voltage readings first. Also take DC voltage readings at the alternator and the battery without the blower and AC on (with just the engine running at idle and no other loads.
Plasticman
I have a new alternator and no issues with the battery going dead.
You are reporting low voltages. Measure the damn voltage (if you want help)!
Plasticman
It is best to find out what you have and not just assume the charging system and battery are fine. Measure the voltage so these things can be rulled out.
14 volts at 650rpm, 15.5 volts at 1500rpm. At the rear of the alternator.
Ken,
Plenty juice. Follow what NEVERL8 suggested and also make sure the blower switch and compressor have a good ground. Because of the current draw in that circuit from the compressor clutch and the blower motor, you may have to install a relay to energize the idle solenoid.
Ken,
Dave
I was also thinking a relay to get a full 12 volts off of the battery and maybe a fusible link just for safety.
The harness for the alternator is new along with the wiring for the A/C. The rest of the wiring is probably mostly original with some splices under the dash for who knows what? Everything works but some of it looks pretty old.
You have a significant voltage drop somewhere. The voltage drop is just the current through the device times the resistence of the device. If you have a high resistence point like a switch contact, splice, connector, high resistence piece of wire, etc. then the volatage will drop across each one of these.
Methodically trace the wiring from the output of the alternator to the carb solenoid you to find your problem. Measure the voltage using the chassis ground as you negative return point. I am not saying this will be easy, the electrical stuff is always the most difficult for me even though I am an electrical engineer.
Ken,
Dave
Dave,
Here is what I ended up doing and also with help from Roy!
After finding out with my original wiring I was not getting a full 12 volts to the solenoid I took a different route. I decided to use a 30 amp relay and 30 amp in-line fuse to get the 12 volts needed. I used the a/c blower switch which turns on my Vintage a/c and wired it to the relay. Then wired the relay to the battery positive cable nut with a 30 amp fuse between the battery and relay. Grounded the relay and ran the last wire to the solenoid. The thing works perfect and I get full voltage at idle which opens the solenoid. The compressor still cycles but my rpm stays right at 600-700 rpm. Ain't it great when something actually works!
Very creative...I had to wire relays into the '61's lighting circuits to get full voltage to the headlights. The old wiring just has enough resistance to be a problem sometimes.
totally, and I will have to re-wire the car some day. I didn't feel like creating a bigger problem chasing wires right now and I know there are some repaired wires that need replacing so maybe next winter a new harness?
