I'm having problems with the water pump gaskets leaking on my C1. All the surfaces for the four gaskets are clean with no corrosion. For anybody that has had this problem before on their C1, is it better to use sealant with on both sides of the gaskets or just use clean gaskets without sealant?
Thanks,
Pierre
Get 4 carburator studs to align the gaskets, moter mount and pump.
Remove the studs one at a time and install the bolts. Some recommend that you "pre-torque" the pump so that when the moter torques it won't break the seal. I also built a JIG that fit around my oil pan to hold the weight of the engine so I didn't bend my pan.
Larry
