67 Hurst Shifter problem.
Old Jun 21, 2009 | 06:01 AM
RickSnow's Avatar
RickSnow
Default 67 Hurst Shifter problem.
My 67 uses a Hurst shifter and linkage with a reproduction "original look correct" handle. The reverse "T" is non functional on these handles. The shifter works fine with the exception that Reverse, First and third gears are so close together it's easy to put it in Reverse or Third when looking for First gear. Can someone please tell me what I can try to correct this situation.....thanks for the help.
Rick.
Old Jun 21, 2009 | 06:09 AM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Rick
I am sorry but I can't help. I have the same shifter and I do not have that problem.
Old Jun 21, 2009 | 03:09 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
I have the same car and shifter (short straight). Your shifter should have a very noticable spring action to keep it in the neutral gate side-to-side position. If left there you would naturally go up into 3rd or down into 4th. In the neutral position you should have considerable resistance to go left and up into reverse. If not, something is most likley not adjusted properly. Having said that, is the shifter new or old. If old the now parent company, Mr. Gasket I believe should be able to rebuilt it for a nominal fee. Dennis
Old Jun 21, 2009 | 03:58 PM
mayordaly's Avatar
mayordaly
Rick, on most of the hurst shifrers there is a guide hole and a tool that looks a plastic allen wrench (you can use an allen) you adjust the linkage rods as tight or loose as you want with the pin in place. hope thats all you need to do.
To 67 Hurst Shifter problem.
