remove return spring on clutch peddle?
Old Jun 21, 2009 | 09:31 PM
turbocat's Avatar
turbocat
Default remove return spring on clutch peddle?
I was reading my shop manual for my 66 and found that it said you could remove the return spring on the clutch peddle for "heavy duty conditions". Since this would lower the peddle on my car about 2 inches and now make it about level with the brake peddle it would make using the clutch much more comfortable. Anyone done this ? If it's in the manual It shouldn't hurt anything?
Old Jun 21, 2009 | 09:37 PM
midyearvette's Avatar
midyearvette
the problem in doing that might drop the pedal past freeplay and ride the t.o. bearing....
Old Jun 21, 2009 | 10:01 PM
turbocat's Avatar
turbocat
If that is the case, then why isn't it cautioned in the service manual when it says you can remove the spring?
Old Jun 21, 2009 | 10:30 PM
67vetteal's Avatar
67vetteal
I also would not recommend removing the Spring. It could produce premature wear of the Throw out Bearing. Al W.
Old Jun 21, 2009 | 10:42 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
I dont have a stock clutch OR pressure plate, I have a McLeod set up. When I put the car together, several people on the forum said that the fingers on the pressure plate would suffice for the pedal return. It has been fine. I don't know anything about your set up, but ask JohnZ, he would have a good opinion on if it would be ok for your set up or not...I like mine and there is no big honking a$$ spring to contend with.
you can see in the photo above that the clutch pedal is about an inch below the brake pedal.....
Old Jun 21, 2009 | 11:00 PM
vetrod62's Avatar
vetrod62
Herb, I am sure that someone will beat me to this, But you and the OP can not allow the clutch fingers to touch the throw out bearing. It will wear out very quickly and with your TKO it is not an easy job to replace. The 66 vette spring set up is different. You do not have use the stock monster spring but you need some other spring located so it delivers a more mechanically advantaged way to pull the TO bearing off the clutch. Maybe 6 lbs.
There was a thread a few weeks ago covering this.
http://forums.corvetteforum.com/c1-a...-question.html
Old Jun 21, 2009 | 11:08 PM
turbocat's Avatar
turbocat
[QUOTE=firstgear;1570530758]I dont have a stock clutch OR pressure plate, I have a McLeod set up. When I put the car together, several people on the forum said that the fingers on the pressure plate would suffice for the pedal return. It has been fine. I don't know anything about your set up, but ask JohnZ, he would have a good opinion on if it would be ok for your set up or not...I like mine and there is no big honking a$$ spring to contend with.
My thought exactly--John ?
Old Jun 21, 2009 | 11:49 PM
stingrayl76's Avatar
stingrayl76
I think what you are reading in the shop manual, assuming it is the same as the 65 manual, is the procedure to change the positioning(i.e., lowering) of the clutch which in turn changes the geometry resulting in a quick release of the clutch. In this position it also will take more effort to push in the clutch. Removing the return spring, to my knowledge, will have nothing to do with lowering the clutch pedal, although as pointed out previously, it can eliminate the free play allowing the throwout bearing to ride on the pressure plate causing premature failure of the bearing.
Old Jun 22, 2009 | 12:16 AM
buns's Avatar
buns
^...It really is there. Page 7-2. "Adjust free travel to 2"-2-1/2" for heavy duty operation. The return spring may be removed for heavy duty conditions."
I wonder if they are talking drag racing?
Old Jun 22, 2009 | 12:23 AM
turbocat's Avatar
turbocat
[QUOTE=buns;1570531647]^...It really is there. Page 7-2. "Adjust free travel to 2"-2-1/2" for heavy duty operation. The return spring may be removed for heavy duty conditions."
John Z?
Old Jun 22, 2009 | 07:11 AM
firstgear's Avatar
firstgear
St. Jude Donor '15
http://forums.corvetteforum.com/c1-a...uestion-2.html
Duntov54 made his own spring bracket, why not just use a lighter spring with the stock locations and mounting tabs? Besides the throw out bearing possibly wearing out, what else am I missing on the location of the mounting and just using a lighter spring?
Old Jun 22, 2009 | 07:33 AM
67vetteal's Avatar
67vetteal
The one item overlooked in this Thread is , where does the Clutch Adjustment Actuate and what can be expected by any Modification of Throw? The Spring, as pointed out by vetrod, can be changed to lessen Depression Force. No Spring at all can only result in Metal to Metal contact. Al W.
Old Jun 22, 2009 | 08:11 AM
MikeM's Avatar
MikeM
I think the "spring" referred to here in the '62/back model is an assist "over center" spring to help depress the clutch pedal with the B/B clutch. That's not the same as the mid-year spring discussed here.
The mid-year used the diaphragm clutch which doesn't require that spring but it does have a spring to pull the clutch pedal back up to the pedal stop under the dash.
If you change to the fast action position, which reduces pedal travel, it also drops the clutch pedal toward the floor. But, if you leave the pull back spring on the linkage, it'll pull the pedal all the way back up to the stop anyway with the same travel as before but with maybe half that action a dead zone and you've gained nothing.
Maybe you could rig a longer pedal stop under the dash and keep the pull back spring? Or maybe you could just leave it alone?
Old Jun 22, 2009 | 09:44 AM
turbocat's Avatar
turbocat
[QUOTE=MikeM;
Maybe you could rig a longer pedal stop under the dash and keep the pull back spring? Or maybe you could just leave it alone?[/QUOTE]
Leaving it alone leaves me with the 2 inch "dead zone" as you said. Leaving the spring on and just lowering the stop would work, but it seems to me the factory would not say you could leave the spring off if it would harm the throw out bearing.
Old Jun 22, 2009 | 10:42 AM
MikeM's Avatar
MikeM
Just for the sake of discussion, if you remove the spring for anticipated "heavy duty conditions", there may be a great likelyhood you will wear the clutch out or tear it up with those "heavy duty condtions", before the throwout bearing goes bad. Which it will, sooner than if you left the spring on it. The more that bearing drags on the clutch fingers and the more you spin it, the shorter the bearing life. Makes sense, doesn't it?
Are you anticipating any really continuous "heavy duty conditions"? If not, I'd put the pedal back to the stock height.
Old Jun 22, 2009 | 11:03 AM
Plasticman's Avatar
Plasticman
From personal experience, the TO bearing will fail in 2000 miles or less (if it constantly rides on the clutch pressure plate fingers even if just light contact, since the TO bearing will be constantly turning - and it is not designed to do that).
Plasticman
Old Jun 22, 2009 | 12:35 PM
Mossy66's Avatar
Mossy66
St. Jude Donor '14
Let's look at this from the other end. The clutch pedal pivot point is aft of the firewall. In the normal clutch arrangement the pedal is held against the stop by the spring. Remove the spring and the pedal wants to swing to the lowest point of it's arc, but the throw out bearing will stop it before it gets there.
Now if we change to the heavy duty or quick release position or whatever it's called, when you release the clutch pedal to the point where the throw out bearing just comes off contact with the clutch, the pedal just might be forward of the lowest point of it's arc, and as the pedal swings to the lowest point of it's arc it is actually drawing the throw out bearing away from the clutch.
This is just a theory that should be further tested.
Gerry
To remove return spring on clutch peddle?
Old Jun 22, 2009 | 12:53 PM
stingrayl76
Buns,
I looked in the 63 shop manual, as I don't have the 66, and Section 7 covers the 3 speed transmission. There is no mention of removing the return spring in the 63 shop or the 65 supplement manuals. Guess it was something new for the 66 model year.
Dave
Old Jun 22, 2009 | 02:12 PM
JohnZ's Avatar
JohnZ
It's a misprint - do NOT remove the clutch pedal return spring unless you really enjoy pulling transmissions and replacing fried throwout bearings, 'cuz that's what you'll end up with. Midyears don't have a "big honkin' return spring" - that's the solid-axle setup.
Old Jun 22, 2009 | 04:11 PM
turbocat's Avatar
turbocat
Thank you John, I guess you can't believe everything you read even if it is in the service manual.
