I just finished my 63 FI vette and have logged about 950 miles. The 2nd cable that goes from the distributor to the high pressure fuel pump has broken. This is my first fuelie and I don't have any past experience with this type of problem. Anyone out there that knows of this problem and has a fix, please let me know. Dave
Both cables are broken in the middle. I bought this car 3.5 years ago and it came with a truck load of new parts that were bought around 1971 & 72. Both cables were in there original GM boxes.
1. You need to make a subjective evaluation of how easy is it to turn the pump by hand. Put a new, bare cable in the pump shaft and turn it with just your thumb and forefinger. If the pump is set up with proper gear clearances and has no other issues, it should turn VERY easily.
2. When you installed the two cables that have broken, did you lubricate them? They need grease to prevent wear. A generous amount of wheel bearing grease works well.
The most frequent cause of a cable breaking in the middle is friction against a rough (or dry) side wall of the cable housing. Overstress breaks usually occur at the distributor end.
Although I've never disagreed with Jim before, I wouldn't say that normal pump seal and gear drag can be very easily overcome with two fingers on a drive cable. The pump should turn over smoothly without any binding, but not very easily.
Not correct, but you can still drive the car without the housing over the cable. In fact its much easier to remove and install the cable with no housing interfering. I ran mine several years without the housing, just too lazy to replace it at times. Currently its installed for anyone wondering.....
i made an 'emergency' cable out of a broken cable by soldering a piece of copper tubing as a splice over the broken portion and ran it without the casing.
emergency cable or regular cable, it will run fine and stay in place without the casing.
try it without the casing and you can see what the cable is doing when the engine runs. it may give you a hint of what's wrong if it flails about.
Bill
Bill
We probably aren't even in disagreement on this matter, given how subjective "very easy" is. For grins, I just tried turning three different pumps via a cable held between thumb and forefinger. Even with my arthritic hands, it was possible to spin all three pumps.
The key, though, is for the pump to turn smoothly, as Jerry rightfully pointed out.
Um....the engine WILL run fine with only the drive cable and no sleeve, HOWEVER, the drive cable WILL come out of your distributor if you run the engine to high speed.................say when you downshift and floor it to PASS another car....the engine will die just as you pull alongside!
that may be true under those circumstances; i don't know as it never happened to me.
Bill
I had it happen to me, twice. It put some permanent kinks in the cable. I then decided it wasn't a good idea to run without the casing except in an emergency or diagnosing. That's back when the cables cost maybe a buck and change apiece.
Thanks for the help. I'm going to put new bushings in the pump and try an other new shaft. Will try without outer cable cover.
be careful... if the pump has never been apart (still has the lead seals in the socket head screws that hold the pump parts together) and/or it's not leaking and turns freely; don't mess with it.
Bill
Bill
The main reason for running without the jacket is to run with a clean (ungreased) cable, so when you park the car, just put the FI drive cable in your pocket and walk away. To steal your car they now need a tow truck.
Bill
Be darned sure the pump needs work before opening it up.
Unless you are a very experienced machinist, please don't attempt this. Those two carbon bushings were align-bored after installation to keep the gear centerlines perfectly parallel and properly spaced. This boring requires close tolerances that you can't duplicate at home.
Those carbon bushings NEVER need replacing unless some Gyro Gearloose has broken one in the past while removing the seal. If one of your bushings is missing, I will give you contact info for the two machinists who have jigs to install them properly. By the way, I am not one of them... and neither is Paragon.
Unless you are a very experienced machinist, please don't attempt this.* Those two carbon bushings were align-bored after installation to keep the gear centerlines perfectly parallel and properly spaced.* This boring requires close tolerances that you can't duplicate at home.Those carbon bushings NEVER need replacing unless some Gyro Gearloose has broken one in the past while removing the seal.* If one of your bushings is missing, I will give you contact info for the two machinists who have jigs to install them properly.* By the way, I am not one of them... and neither is Paragon.
I have a very experienced machinist and if we determine the bushings are bad he is very capable. Thanks for your info. GM had two different lenght cable housings and cables. How do you determine which one is correct and why did GM make two different lenghts?
Not to be deliberately terse or abrasive, but if Jerry says there are exactly two machinists he'd trust to install the carbon bushings, then there are EXACTLY TWO machinists qualified to do the work. Period.
Jim
