There may be a triangular brass-colored tag attached to one of the screws on the upper carb. This tag would have numbers embossed in it which serve to identify it's use.
Jeff
Thanks it has the triangular Tag that reads 70190 as best as i can make out
It may be 7019014 but its very hard to make out the second to last number , Then on the bottom of the tag it reads 01 07 This card sits on a 58-61 manifold 3746829 , Does this help
Note: That web site is not a comprehensive listing of Rochester carbs, it appears to be focused on Chevy applications and is, for example, missing the 7007221 carb used on my 1956 Oldsmobile.
From: Putnam Valley, New York. Amateur Radio Operator K2NS
If I remember correctly, the 4th digit denotes the model year that the carb was used on. Yours is a "9", denoting 1959. You say that the manifold is a 1958-61, so the 1959 makes sense. There must be a chart somewhere on the web that will decipher the "014" and tell you what the original application of the carb was, but where to find it, I don't know. One thing I do know, is that Rochester 4 jet (4G, 4GC, and 4GV) carbs were NEVER used on Corvettes. They were however used on the rest of the Chevrolet line and all other 4 divisions of GM.
