Okay, here I am now having put my dash back together and my tach started making little tick-tick-tick and then squealing noises. Got under the dash and saw the cable was loose attaching to the back of the tach. No problem. Not easy to tighten all assembled but I did my best. Lasted for about a week. Noise starts to come back. Again I get under the dash and I was able to use some long bent nose pliers and gave it a bit of a turn. All good.
Today I driving and the tach dies. It goes to zero and that’s all she wrote.
I decide to look at the cable attached to the distributor and I’m surprised to see the black casing has almost separated from the chrome part attaching to the distributor (I even see some wire frays from the cable). I attempted to remove it from the distributor and that sucker is stuck tight. Came out after a lot of coaching. The cable is all frayed as if the tach side stop and the distributor side continued to spin for a while.
Tomorrow I’ll try to get under the dash to disconnect the cable from the tach and see what I’ve got.
What’s going on here???
Oh.. Of course I had replaced perfectly good cables for the Tach and speedo when I did all the work. Seemed like a good idea at the time.
How severe is the angle of the tach cable where it enters the distributor? If the cable is coming into the distributor at an angle, it can put some serious side-loading on the cable, and I would that could help destroy it in a heartbeat.
I'm typing with one hand since my right arm still doesn't have any feeling... I replaced my tach cable without pulling the cluster, just did it in place. Used a pair of long, bent needle nose pliers. I don't want to do this again any time soon but it was definitely worth it. Tach is working again. The first cable I installed I was a little too 'creative' with the way I routed it. Worked for less than two weeks then seized up. All is good!!
I went thru two tach cables b/4 I found out that the cable was too long and caused bends that would make it brake. Make sure you have a cable that is the right length.
The cable came from Paragon (I thought they would have the right parts). It's a 27" long cable but it is longer than the one I threw away (so I don't know the length of what I had). I did have to do a bit of an 'S' bend at the dist. I do see a bounce at < 1500 RPM. We'll see. Last time it lasted <2 weeks. so far so good.
Is the drive cable plastic? I was sent a new tach cable and the drive cable was plastic. It was horrible, bounced all over. I was going to use it until I got my original cable restored. Just went without for a week or two until my original was good to go.
Mark
Its nice. The cable is steel and the casing is black and looks well made. It just may be a bit too long. Now, I do have a Mallory dist. The connection is on the left, front side and its aimed almost towards the cable firewall hole. I had to snake the cable towards the wiper/washer and back to the dist. Is the cable connection for my Mallory different than stock?
The 27" cable from Paragon does seem excessively long, but it works well in my car. The cable from ZIP is quite a bit shorter, and i elected not to use it. The added length allows some flexiblity in the routing, make sure it has no sharp bends and curves smoothly all the way.
The original cable was GM p/n 3866126; this cable was 24 1/8" long. It was replaced sometime around 68 (I can’t read my notes on this) with part number 6476986 which also carried the exact same measurements. 6478117 was the next number then followed by 6470367 which was made to accommodate both the mid year cars as well as the 1968 (which had a screw on cable like the mid years). Next new number for this cable was 88959456 which was listed at 24.61 in length.
So there you have some cable history! We carry the 88959456 cable it’s not on our web site and higher than the reproduction cable. It is a workable GM replacement of the original cable and you may be able to find this cable at a local parts house if you check.
Now this is a bit of an irony here: for years we sold and installed the 6470367 cable and it worked fine. However, from time to time we would have people call us and tell us the cable was to short. I’m not really sure the cable was short but it was a close tight fit. I have installed the old 6470367 repeated times with no problems. I could only assume the 88959456 would do just fine except for the look.
A little trick to help ease the installation of either the tach or speedometer cable is to go to the hardware store and get two 1/4 x 20 by 8 to 10 in long bolts. Take the screws out of each end of the dash and install the 'long ones' in their place. Next take out the rest of the screws. Once you have done that your dash will now 'slide out' enough to get your paws up behind the dash and get a good grip on those cable ends...
