dash board light intensity
Old Jul 16, 2009 | 10:24 AM
1911colt's Avatar
1911colt
Default dash board light intensity
Hello all!! Hope you can help me.I've had my 66 Conv. now for 34 years and the dash lights have NEVER been bright enough.I've replaced the headlight switch to check the reostat and that didn't help. I've replaced all the bulbs with new correct bulbs from PIP and that didn't work either.Would appreciate any suggestions Thanks in advance..
Old Jul 16, 2009 | 10:39 AM
66jack's Avatar
66jack
are all your grounds on the back of the dash TIGHT...???
jack
Old Jul 16, 2009 | 11:29 AM
1Sweet66's Avatar
1Sweet66
jack
I just redid my '66 cluster myself and replaced all of the bulbs ( most original and 43 yrs old ) with the same #1816 bulb. It seems plenty bright enough at night. Some have suggested in the past using a #1817 bulb that has slightly higher wattage to brighten up the cluster. These are not easy bulbs to find and some reported that they are in the $2 each range.
Check the grounds first. I actually added an additional ground to the back of the cluster just to make sure.
Old Jul 16, 2009 | 03:45 PM
67vetteal's Avatar
67vetteal
I just drove my car "In the Dark!", last night. I recently installed the #1817 and the Dash Lighting was just right. (I'm 64, if you know what I mean.). Atlanta Elecric has them. Al W.
Old Jul 16, 2009 | 03:59 PM
JoeCool66's Avatar
JoeCool66
(maybe except for that part about being 64.... )
Old Jul 16, 2009 | 05:52 PM
1911colt's Avatar
1911colt
Thanks folks Looks like I'll try some 1817 bulbs!!
Old Jul 16, 2009 | 06:43 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
just a thought but your cluster could be just dirty inside.
Old Jul 16, 2009 | 07:30 PM
Kensmith's Avatar
Kensmith
Just some dust build-up will reduce the brightness. But new bulbs are nice too!
Old Jul 16, 2009 | 07:43 PM
Nowhere Man
also depending where the car was all of its life the plastic lenses might be starting to haze a little and reduce brightness
Old Jul 16, 2009 | 07:46 PM
54greg's Avatar
54greg
I was having the same problem with my 66 vert. When I rebuilt the cluster I added a ground and the dash lights have never been brighter
67vetteal's Avatar
67vetteal
Pledge Furniture Polish does wonders for Haze. Al W.
Old Jul 16, 2009 | 08:16 PM
LB66383's Avatar
LB66383
If the cluster has never been done, it's possible a lot of the paint has flaked off inside. When I redid the cluster on my '66, I repainted the light green on the inside of the cluster, and it's quite a bit brighter than it was.
Old Jul 16, 2009 | 10:08 PM
Avispa's Avatar
Avispa
Thanks a million for the #1817 light bulb recommendation. I've checked catalogs for years and thought the 1816 was the best you could do.
I can actually see my fuel/battery/temp and oil gauges at night!
Old Jul 17, 2009 | 09:12 AM
1Sweet66's Avatar
1Sweet66
My '66 dash gauge lenses were glass. Cleaned them in the sink with dishwashing liquid. Are other years plastic? (I think the clock is plastic, probably due to the hole)
Old Jul 17, 2009 | 05:39 PM
65 vette dude's Avatar
65 vette dude
65 lens are glass,the clock lens are plastic.
To dash board light intensity
