another brake light problem
Old Jul 18, 2009 | 07:14 PM
o2bnkc's Avatar
o2bnkc
Default another brake light problem
Help! I've got a 65 that originally had the back up lights. Not now. (I bought it like this) Now the setup is:
outer lights used as running lights, brake lights and turn signals
inner lights used as brake lights and turn signals
My problem is that I have no brake lights on the passenger side. The lights still work correctly for runnings lights and turn signals, but no brake lights. Any ideas? Thanks.
Old Jul 18, 2009 | 07:37 PM
Ron Miller's Avatar
Ron Miller
Check to see if you have current to the brake light switch, and if so, check the switch.
Old Jul 18, 2009 | 07:51 PM
CWPASADENA's Avatar
CWPASADENA
If the Brake Lights work on the Drivers side and the turn signals work correctly on both the drivers and passanger sides, I would suspect the turn signal switch. The R/H brake light wiring, sockets and bulbs would be good if the R/H rear turn signals work because it is all the same circuit. The contact in the turn signal switch that switches that circuit from R/H brake light to R/H turn signal is probably bad.
I do not think it would be the brake light switch. If there was no current to or from the brake light switch, neither L/H or R/H brake lights would work.
Chris, CWPASADENA
Old Jul 18, 2009 | 07:56 PM
Ron Miller's Avatar
Ron Miller
Chris is correct, I missed the part about brake lights on one side only. If they work only on one side, you're not getting current to the inoperative light somewhere from the turn signal switch to the light, or possibly a bad ground on that light.
Old Jul 18, 2009 | 08:18 PM
CWPASADENA's Avatar
CWPASADENA
If the R/H rear turn signals work, I do not think it would be a bad ground. If it was a bad ground, neither the R/H rear turn signale nor the R/H Brake lights would work.
Just my thoughts,
Chris, CWPASADENA
Old Jul 18, 2009 | 08:24 PM
vettn's Avatar
vettn
I have worked on this problem too and I am pretty sure you have a contact in the turn signal switch not making contact. If you don't want to replace the whole turn signal switch, you can just bend the contact tangs. Or do this to check and see if this is the problem before you put in a whole new turn signal switch. I have pictures I can send you of what to look for if you want. Using a test light and small needle nose pliers is about all you need once you get to the switch under the steering wheel hub. Email me direct so I have your address.
Gary
seymour@sosbbs.com
Old Jul 18, 2009 | 08:29 PM
CWPASADENA's Avatar
CWPASADENA
Gary
seymour@sosbbs.com
I have fixed a bunch of them this way. Just use a little caution as you are dealing with some small little parts. I would try to fix it before I would replace the entire switch.
Chris, CWPASADENA
Old Jul 18, 2009 | 08:31 PM
Ron Miller's Avatar
Ron Miller
Just my thoughts,
Chris, CWPASADENA
You can have a failure to ground in the bulb socket as well . . . .
. . . . but likely the turn signal switch . . . here's a picture of the inside of a turn signal switch I just finished working on because of a similar problem.
Old Jul 18, 2009 | 10:09 PM
o2bnkc's Avatar
o2bnkc
Thanks for all your help folks. Looks like I will be checking the turn signal switch. If somebody has another thought, please let me know.
Old Jul 22, 2009 | 01:02 AM
o2bnkc's Avatar
o2bnkc
That was my problem. I just kind of rebent the metal strip around a little and it works.Thanks for all the help and suggestions, everybody.
Old Jul 22, 2009 | 07:38 PM
CWPASADENA's Avatar
CWPASADENA
Good Job;
We all knew you could do it.
Chris, CWPASADENA
To another brake light problem
