57 speedometer
Old Jul 19, 2009 | 09:54 PM
michael m baily's Avatar
michael m baily
Default 57 speedometer
My speedometer needle has been acting erratic, I replaced the cable, it did not help,I have taken the speedo out before and know it is not difficult, question is what is making the needle jump all over the place, 0 then 140 ,then o, never does show the correct speed, is there something in there I can fix or replace or does it have to go out for repair. strangely the odometer works. thanks Mike
Old Jul 20, 2009 | 12:20 AM
54greg's Avatar
54greg
Thats what my 54 speedo did right before it quit for good. It's not a bad repair. If your case is in good shape try a local speedo shop, you'll be surprised how quickly and inexpensively they are rebuilt if parts don't need to be rechromed.
Old Jul 20, 2009 | 09:28 AM
1954corvair's Avatar
1954corvair
The needle is attached a bell housing which is sodered on. The soder breaks and then the needle acts erratic. If you need help I can assist you with it. These are not complex and very easy to fix.
Old Jul 20, 2009 | 05:55 PM
michael m baily
Thanks 1954 corvair for the reply and help, I have the speedo in front of me out of the housing, I see that the needle is attached sodered I guess to a small disc, when I move the needle the disc moves but there is small bump on the disc that hits a stop on the housing at about 60 mph mark on the dial. I do not want to remove the housing, looks like two screws until I talk to you, speedo shop wants $130.00 to fix it, please email or call me mikbly@msn.com or 206-909-6180 Seattle, thanks Mike
Old Jul 20, 2009 | 10:33 PM
Fitzaer's Avatar
Fitzaer
Cruising
Default I believe the cable
from the drivetrain spins a magnet in the speedometer. There is no direct connection, no gears. The spinning magnet induces a field which causes a plate attached to the needle to move. The needle's movement is restricted by a coil spring, resulting in an accurate reading. (If I'm wrong, please forgive me, I gained this knowledge repairing the speedometer on a '62 Buick LeSabre when it wasn't very old. For some reason, 'can't remember why, the magnet was actually contacting the plate, causing a whole lot more needle movement, all the way to 120 where it hit the peg and bounced back to zero.)
But the needle on my '57 fell right off and, as my mini-soldering skills are non-existent, I shipped it off to Bob's Speedometer (I liked the name) and Bob fixed it beautifully.
Old Jul 21, 2009 | 07:35 AM
1954corvair
I'll give you a call to help you today.
Old Jul 21, 2009 | 07:40 AM
1954corvair
Your right on the money in description of how it works and I'm glad Bob's speedometer did a great job for you.
To 57 speedometer
