62 black interior
Old Jul 22, 2009 | 04:18 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Default 62 black interior
I am thinking of painting the interior pieces for my C1:
Top/lower gauge housing
Center console
dash ends caps
package tray
heater console cover.
Radio and defroster bezels
Steering column cover and column pieces
kick panels
with a single stage paint. I have some pieces which I can use to do the color correction. Would a single stage application work for these parts or should I think about a base/clear instead? Also, would a quart be enough paint?
Will the single stage paint hold up the sun with the top down?
Old Jul 22, 2009 | 04:23 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
I doubt there is any paint strong enough to, "...hold up the sun".
C'mon they used to paint the entire cars with single stage and the paint held up well... I think that is a safe route if that is what you choose to do...
Old Jul 22, 2009 | 04:53 PM
whitmcfarlin's Avatar
whitmcfarlin
Single stage should do well on those components.
Old Jul 22, 2009 | 05:09 PM
jimh_1962's Avatar
jimh_1962
Is there anything I forgot as far as the interior parts? The interior is black. Did you paint your interior basecoat/clearcoat?
Old Jul 22, 2009 | 05:58 PM
wmf62's Avatar
wmf62
St. Jude Donor '07
base coat/clear coat will be too shiny. mine is still done in unbuffed lacquer from almost 30 years ago
Bill
Old Jul 22, 2009 | 08:43 PM
Frankie the Fink
Army
No... I used black enamel...
Old Jul 22, 2009 | 09:43 PM
bigearl56's Avatar
bigearl56
Default Paint Question
James, I used the following:
Dash Cluster, Kick Panels, Package Tray, Console, got Base Clear. Every thing else was single stage except end caps which got Krylon. Had to do them three times before I got them on without the screws chipping paint. I finally put some grease on the underside of the head and went real slow. As you know the end cap screws go in fiberglass and will strip very easily. During mock up my screw holes were toast so I made a small metal plate and glassed it in behind the old screw holes. Drilled it and let the screws cut as they go. Caps now fit tight and snug.
Good Luck
Earl
Old Jul 23, 2009 | 04:23 PM
Joel 67's Avatar
Joel 67
James,
If you are going to do it yourself, I think you may find lacquer much easier to use than single stage. You could even do it with a spray bomb if you wanted and achieve a good result.
Just my $.02
Joel
Old Jul 23, 2009 | 05:42 PM
david srour's Avatar
david srour
Has anyone tried powder coating the cluster? Not sure if a good idea with potmetal.
Old Jul 23, 2009 | 08:35 PM
Ironcross's Avatar
Ironcross
Default Heres some Pictures
the paint color is just the unrubbed black body color, the OE tuxedo black....
To 62 black interior
