Basic Engine Machining & Building Tips
Old Jul 24, 2009 | 10:57 PM
Engine Doctor's Avatar
Engine Doctor
Originally Posted by Shurshot
And I agree with you and believe that Ghostrider's comments were spot on
So
How do you check
Your clearances
Just wanna know
Peanut butter Or snickers.....Plastiguage.....
Everyone has their own way...Fine by me
Old Jul 24, 2009 | 11:28 PM
Shurshot's Avatar
Shurshot
Originally Posted by Engine Doctor
So
How do you check
Your clearances
Just wanna know
I just did this yesterday with a friend using the old school method of light tension springs and clay.......... ended up with .071 with the lash on the intake but I run pretty stiff springs. (255)
According to Reher Morrison the actual clearance with an already compressed gasket using his method would have yielded another .020
Here is his method of doing it but I did not have the luxury of a spare 2.30 valve nor did I have a used 4.5 gasket.
http://www.rehermorrison.com/blog/?p=186
Doug
Old Jul 24, 2009 | 11:36 PM
Engine Doctor
Doug
What does any of that have to do with a BLUEPRINTED ENGINE ASSY:
Please educate me:o
Old Jul 24, 2009 | 11:43 PM
Shurshot's Avatar
Shurshot
Please educate me:o
You said clearances and piston to valve clearance is what I am currently dealing with
Perhaps you would rather speak with a machinist
Doug
Old Jul 25, 2009 | 12:35 PM
Engine Doctor
oops, Sorry Doug,
I thought the subject was "Short Block clearances ",which is what I
have been refering to(oil clear. etc).
Was not aware that u were working on V/P.
I'm open for discussing & helping with anyone, and a little humor goes a long way!!
Good luck with your project
David.
Old Jul 25, 2009 | 01:36 PM
Shurshot's Avatar
Shurshot
oops, Sorry Doug,
David.
Thank you David
I realize that I am only a novice but having to do things twice or wish that I had planned ahead a little better are not things that I want to haunt me if things do not work out. IMO it is bad enough when the unexpected takes it toll but I do not like to think that something negative could have been avoided.
I have found that to work well for me even if it does upset others who "know better" than I do.
So therefore after assembling the parts that I hope to be using I did a hands on trial mockup with the block, one piston/rod combo, one head and the valvetrain with the cam degreed in......... so far so good
After a couple of years and two blown motors because of problems with quality concerning parts, labor and erroneous "expert opinions" I feel like Sulivans law that simply stated said the Murphy was an optimist.
Consequently I will be reading your posts here looking to glean what I can
Doug
Old Jul 25, 2009 | 06:27 PM
Engine Doctor
Hi Doug...Thank's for you reply
You know there is nothing wrong with you being a Novice !
In fact I've been doing this for over 30 yrs & if it was'nt for
the fact that I keep my eyes and ears open to learn more each and
every day...I would not see any point in being an engine builder/ Machinest:
I love what I do & I do not do production work. What I do is my best with every project. Anyhay...Your mock-up aka Pre-Assy is the absolute
best thing you could do. I do not intend on posting any Hi Tech stuff here...just helping pointers for u guy's. Yet if anyone needs my help,I'm just a phone call away . Once again be confident in your build...Sure it will be awesome! Looking fwd to hearing about your results
David
Old Jul 26, 2009 | 12:51 AM
BLOCKMAN's Avatar
BLOCKMAN
FOR PIC'S VIEW MY SITE @ www.aanddengines.com "Click Services".
First all parts must be thoroughly cleaned prior to inspection,magnafluxed and may need to be
pressure tested to insure absence of defects. Check & Mic. parts to find out what needs to be done as far as Machine Work etc. to obtain desired tolerances & clearances for your application.
1. Inspect for cracks/flaws on the block decks around the cylinder head
bolt holes and between the cylinders. Inspect the main web & main
saddles as well. Check cylinders for size & condition.
2. Check decks for straightness,surface if needed. (Removing +/-.003 your Vin#'s will be visible)
3. Inspect cam thrust and lifter bores & machine as needed.
4. Tork main caps to specs. and check I/D with a dial bore guage for
size.Note that caps must fit in registers snuggly & not rock.Machine as needed
5. Bore & Hone cylinders to piston manufacturer's spec's. Adjustments will be based on engine use
,...Leave +/- .003 for honing stock.
6. Inspect & chase all bolt holes with a dull tap and use tapping fluid.
7. After machining, clean & prep block for assy, Install cam bearings &.
check cam fit . NEXT TIME CONNECTING ROD WORK!
I looked over your website and noticed your decking your blocks in a Bridgeport off the pan rails, Take a block and measure from the pan rail down to the main bearing housing bore as we have seen them off as much as .006
The block should be square decked of the cam and crank center line for an true 45 degrees and will put the decks 90 degrees from each other and machining off the mains will have your decks square with the mains which is a must.
Here is a link on blue printing a block I did years ago and granted not every block needs the cam tunnel and lifter bores done but should be at least sqared and decked, bored and plate honed for a good job.
http://www.chevelles.com/forums/showthread.php?t=93124
Just measuring the main housing bores does not mean they are in line with each other as I am a big advicate of line honing as we just went through a block for a customer on this site which had 400 miles on the engine and the bores measured with in spec but look at the pics and you can see the problems with alignment.
Old Jul 26, 2009 | 01:56 PM
Engine Doctor
Hi Carl ! First off we are not indicating off the pan rail as you stated,2nd. That condition you stated about .006 from pan rail to main is indicative to a condition known as "Factory Tolerance Stacking" as you already know, And lets move on:
Thanks for reading my post. Regarding your statement about milling
machine operations and what can be done on one,from an engineering
standpoint, I am in disagreement with your statement. There are many,many
ways, different ways,to machine anything provided the experience is their. Ex: Boring cylinders is even done on milling machines. BHJ offers many tools specifically designed for the mill...Research it out ,You may also contact Goodson's engineering Dept. for more research about this subject.
I viewed the main bearings you posted and I agree their is a alignment issue there. Obviously when mains are being inspected, the mains must
be checked for alignment,size,register fit,cracks around oiling holes in mains, main web area & caps magged. The alignment issue should have
been caught during inspection or pre-assy, as you know. Apparently whoever did the final assy here,didn't know any better,for sure that
rotating assy had drag & clearance issues that you could feel just by spinning the crank.
As far as Main housing operations, I much prefer "Line boring & honing"
as opposed to" line honing," especially when dealing with spun bearings or cap replacement.. In fact I beleive that a Vertical line bore and hone
is far better yet ,opposed to horizontal work. Also check the mains not just for vertical clearance, but at 90 degrees as you know.
I just this year had a friend pass Jay @ Taylor Engines in Whittier Ca.
He was one of the best,I was fortunate to at an early age learn from his endless experience & I thank him for that!! (u may know him)
In closing...The fact is that engine rebuilding is not limited to engine rebuilding equipment exclusively. Many would be suprised at what can creatively be done on a Milling Machine & a Lathe., Oh and I'm sure you've heard the Old saying...."It's not the machine,but the operator."
Thank's again for your reply,Chat soon! P.S. I viewed your "Blueprinted Engine" NO math/clearances shown...Why is that ? What were the clearances on that assy,curious?
David
Old Jul 26, 2009 | 07:26 PM
Engine Doctor
Default BASIC CONNECTING ROD WORK "basic"
These are basic tips only...(SBC RODS) as an example;
1. clean,inspect,mag or you can use dye penetrants as well,to detect
cracks/flaws.
2. Check all dimensions: pin end(reciprocating end) Big end (Rotating)
Lenth (center to center) & Straightness. .
3. Deburr rods to prevent stress risers, shot peen for strenth & Machine
as needed. Typically you will only need to size the big end (with new
rod bolts). Not expensive work ! ( this is part of your oiling system/ & very little room for error !)
4. SBC stock rod lenth @ 5.700
Big eng @ 2.224 7/10 to 2.225 2/10
5. Balancing your rotating & Reciprocating weights as well as checking
your oil clearances during pre-assy is the only way of being sure of
whatcha got. (New rods need to be inspected too IMO)
THERE IS MUCH MORE TO ROD WORK, GIVEN THE APPLICATION
Old Jul 26, 2009 | 07:32 PM
bonehead2's Avatar
bonehead2
Are there really advantages to floating pin(spira lock) versus pressed in pins on sbc assemblies?. The original "pink' rods were floating pin?.
Old Jul 26, 2009 | 07:36 PM
midyearvette's Avatar
midyearvette
the only advantage to a full float pin is the ease of assembly and at tear down .....
Old Jul 26, 2009 | 07:46 PM
  #33
Engine Doctor
100 percent agreed..but drilled pin ends for lubrication on the rods &
pistons is an absolute plus as well
Old Jul 26, 2009 | 07:51 PM
  #34
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
cracks/flaws.
3. Deburr rods to prevent STRESS risers, shot peen for strenth & Machine
Fixed it for you.
Old Jul 26, 2009 | 08:05 PM
  #35
BLOCKMAN's Avatar
BLOCKMAN
David
I had all the BHJ equipment they sell as we used it before the 2 CNC machines as I have been building performance engines for 36 years now and have a good idea what it takes to machine a block and do it right and I have 2 Bridgeports and would I ever deck a block on a Bridgeport and consider it as good as using a BHJ fixture or a CNC machine I would say it would not be close enough for me.
Most old Bridgeports are not very accurate when loading a 180 pound peice of cast iron on the table and moving left to right as they will leave a bow on the decks high in the middle and low on the ends.
And by the looks of your machined it looks to be painted with a yellow spray bomb maybe to make it look new I don't know. Hey if you can duplicate what we can do with your Bridgeport congradulations.
What are you looking for as I believe there are 2 block in that post and when we machine a block we have the ability to probe the block out in .0001 and that as it a has an automatic probing cycle that checks cylinder locations in X and Y locations deck heights we can check lifter bore locations and cam tunnel locations as well.
Again what clearances are you looking for??
Old Jul 26, 2009 | 08:16 PM
  #36
Engine Doctor
Originally Posted by claysmoker
Fixed it for you.
THANK YOU
Old Jul 26, 2009 | 08:32 PM
  #37
Engine Doctor
Why are you so defensive
So much for "A community of engine builders educating the consumer":
No wonder people are afraid of engine builders
Do your work your way ..Never said anything was wrong with that!
And I did not offend you...Child's play
Proof is in the pudding...my customers keep coming back
We both know what #'s mean on a build ..& I'm never ashamed to show them. Are You???
To Basic Engine Machining & Building Tips
Old Jul 26, 2009 | 08:41 PM
  #38
BLOCKMAN's Avatar
BLOCKMAN
Proof is in the pudding...my customer keep coming back
Also I don't need to know your clearances...I CONTROL MY OWN
You asked this question so what math/clearances do you want to know about your so curious!!!!!!!!!
And only having one customer does not say much or maybe it does LOL
Old Jul 26, 2009 | 09:06 PM
  #39
Engine Doctor
Ya u r lol
Old Jul 26, 2009 | 09:18 PM
  #40
MikeM's Avatar
MikeM
Who couldn't see this pecker wavin' comin' starting with the first post!
