3782870 Casting
Old Jul 27, 2009 | 08:49 PM
raritan's Avatar
raritan
Default 3782870 Casting
Do all corvette engines have the 2 to the left of the casting number.
ie 2
3782870
thanks
Old Jul 28, 2009 | 02:24 PM
JohnZ's Avatar
JohnZ
The "2" is a foundry pattern number - there were MANY multiple patterns for high-volume castings. The 870 block wasn't unique to the Corvette - it was used in millions of passenger cars and trucks too; the block was the same for all applications - only the innards and bolt-on parts made it a "Corvette engine".
Old Jul 28, 2009 | 04:46 PM
Woodie's Avatar
Woodie
But the dates also made a difference if I'm not mistaken. As I have two 1963 Corvette engines that use just the 3 in the date code but I have an 870 block with a date code of 63 which is not a Corvette engine
Old Jul 29, 2009 | 01:55 PM
JohnZ's Avatar
JohnZ
That's correct - if the date code has two digits for the year portion and there's no plug at 11 o'clock just above the timing cover, it's a Tonawanda block, and they weren't used in Corvettes.
To 3782870 Casting
