Speed nuts
Old Jul 27, 2009 | 10:50 PM
JimSR's Avatar
JimSR
Default Speed nuts
Who ever came up with the name speed nut they are the pain in rear. Especially the ones on the tail lights on the mid years. I was about ready to glue the lights in.
JIm
Old Jul 27, 2009 | 10:53 PM
62Jeff's Avatar
62Jeff
They were probably quite handy when installed under force with a powered tool of some sort. But if installing them with a manual wrench, on a new stud necessitating the cutting of threads, well they sucko mucho.
Old Jul 27, 2009 | 10:56 PM
sub006's Avatar
sub006
They do a great job of holding the headlight doors on my Grand Sport. With the gentle twist of a screwdriver.
Old Jul 28, 2009 | 01:19 AM
Astrodokk's Avatar
Astrodokk
I used them to screw in my rocker panels to the frame. They slipped right over the enlarged holes and allowed a tight fit. I'm glad I found them.
Old Jul 28, 2009 | 08:46 PM
Kensmith's Avatar
Kensmith
I use to have Speed Nuts, but something happened to them when I turned 60. Now I think they are called Hang Nuts!
Old Jul 28, 2009 | 10:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
if they wont hold tight on the stud. take the speed nut and gently tap down to close up the hole
Old Jul 28, 2009 | 10:24 PM
Ron Miller's Avatar
Ron Miller
If you're installing them back where they came off of, it usually helps to turn it backwards just enough to where you can feel it catch the old thread it came off of, then, turn it clockwise to put it back into the same thread it was removed from. (Make sense??)
If they're going on a new stud that has never had threads cut into it, it usually helps to apply a little pressure on the nut to help it engage the stud.
If it slips or doesn't catch, refer to the above post suggesting you tap it to close up the opening slightly in the speed nut.
This is what works for me.
Old Jul 29, 2009 | 10:39 AM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
I use handle type socket wrenches. The ones with the plastic handles and the socket at the end. Also, it helps to put the speed nuts onto the part before putting the part onto the car.
Old Jul 29, 2009 | 11:57 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
If the nuts are going onto new/repro parts to cut threads (e.g. side spears of fender windsplits) I spray WD40 onto the studs on the new part and carefully screw the nut ALL the way down very carefully and very straight BEFORE installation. Its too easy to break those cheesy studs off if you are trying to thread them with speed nuts while laying upside down under a dashboard...
To Speed nuts
