Chrome questions...
Old Dec 10, 2010 | 03:45 PM
Olustee bus's Avatar
Olustee bus
Veteran: National Guard
Pauls is really good. However, I had mine done right down the road from you at Knoxville Custom Chrome. They do good work. What impressed me was that the fellow running it, I guess he was the owner, asked me if I wanted the tops of the bumpers smoothed out. He said some people wanted that but as far as an accurate restoration, he would not recommend it as all C2's have small waves on the top of the bumpers.
The shop does not polish stainless but a couple of employees do. They did a great job on my windshield wiper blades.
And as to losing parts, that want happen at Pauls. They expect a complete list when you recieve it, they make a complete list along with photos of every piece and send a receipt for you to sign.
As far as triple chrome, it was explained to me that no one does that anymore.
I hand delivered mine as I did not want to take chances
I will say this and I don't know if it would be a problem or not. When I dropped off the bumpers, they wrote up a ticket and then took the bumpers out front of the shop and laid them down. I left and began to get nervous about that. I called them back and asked if they are gonna take them inside at night. He assured me they were.
Old Dec 10, 2010 | 03:53 PM
VetteJohn's Avatar
VetteJohn
Default Va. Vettes
One more vote for Va. Vettes. Dick has a source that does excellent work on chrome. He's handled both a '56 and a '62 I've restored and everyone says good things about the bright work on both cars.
You also get a bonus with Va. Vettes, Dick is a straight shooter. If there are issues he works to fix them to your satisfaction. Give him a call: 757-229-0011.
Old Dec 10, 2010 | 05:33 PM
Chambered's Avatar
Chambered
As far as the actual chroming, I don't know any platers anymore that still use copper. Copper is so caustic, I think the EPA has almost forced the chrome platers to go away from it & everything now is usually 2-step nickel, then chrome. VA. Vettes can verify this. If the nickel dips (& everything else) are done correctly, the chrome job should be excellent.
Old Dec 10, 2010 | 05:58 PM
firstgear's Avatar
firstgear
2019 Corvette of the Year Winner
St. Jude Donor '15
Originally Posted by firstgear
I used Pauls, great results....but a lot less than Jon Wright out of Grafton, Ohio (he is supposed to be top notch, but the lead time and cost was really crazy).
I had a spot show up under one of my front bumpers a couple of years AFTER they were done by Pauls. I sent it back and they covered it under warranty! Great to deal with.
Old Dec 10, 2010 | 07:02 PM
GCD1962's Avatar
GCD1962
The chrome is more EPA "bad" than the copper. Yes triple is still available and prefered as it gives more depth. Old time "rack plating was the 2 step nickel then chrome. The quality of the work, more often than not, is in the prep (labor cost) and not so much in the actual plating. If the tanks are clean and handled properly parts plate correctly. Good parts in, good parts out, Not so good parts in, not so great quality. The advantage with copper first is that it's easier to see and defects. A good plater will copper, re-buff and dip again if necessary before going to the nickel, then the chrome
Old Dec 10, 2010 | 11:42 PM
5thvet's Avatar
5thvet
Originally Posted by Virginia Vettes
We do use outside platers and pass on the volume discounts to our customers. Our pricing speaks for itself. This week we did 8 bumpers, 6 grill shells, 4 door posts, 6 windshield posts, 4 door handles,1 grill bar,and a pile of small parts.
Dick,
Can you advise the charge for 4 tail light assemblies and 2 door handles? ( and lead times)
Don
Old Dec 11, 2010 | 07:09 AM
Virginia Vettes's Avatar
0Virginia Vettes
Former Vendor
Originally Posted by 5thvet
Dick,
Don
Thank you for the inquiry.
I respectfully stay away from taillights for three reasons.
1) They are an assembly. The chrome cup has to be separated from the other components or everything gets plated.
2) The lights are a cup. The plating will attach to the rim very nicely but plating does not like to go down inside the cup leavening the customer with poor results. The cup also it very difficult to polish the pitting out
3) We sell Trim products reproduction taillights at a discount, that are made in the USA, and have a track record of excellent quality.
Old Dec 11, 2010 | 08:35 AM
John McGraw's Avatar
John McGraw
Every plater I know of still uses copper! A lot of the OEM's now do not use it, but most aftermarket chrome shops still do. The copper fills all the little scratches, pits and imperfections. Think of it as the body filler of the plating business. For really nice show-quality chrome, copper is still a must. The copper process is way less of an environmental issue than almost anything else in a plating shop. Shops skip the copper process simply to save money and deliver the parts cheaper and faster.
Unless a new process has been developed, plating of pot metal trim still REQUIRES a copper strike coat prior to the nickel. The nickel plating solution is very aggressive and will attack the pot metal if it is not protected with copper.
Regards, John McGraw
Old Dec 11, 2010 | 10:39 AM
5thvet's Avatar
5thvet
Thanks for the honest answer. I'll check out the Trim parts on your website.
Don
Old Dec 11, 2010 | 11:00 AM
Ron Champe's Avatar
Ron Champe
Perfect answer...Cheaper and better to buy and install the Trim Products taillights. Excellent product.
Old Dec 11, 2010 | 01:17 PM
JohnZ's Avatar
JohnZ
Absolutely, on show chrome (although GM didn't use it originally - they just used nickel and chrome). Copper is the foundation of a quality plating job. Here's a rack of Paragon midyear bumpers fresh out of the copper tank, awaiting polishing before getting nickel and final chrome.
Old Dec 11, 2010 | 02:18 PM
Corbrastang's Avatar
Corbrastang
Originally Posted by Grey Ghost
Have you checked out Advanced Plating in Nashville ?
+1 They are not speedy or inexpensive, but they do fantastic work. They fixed and replated the rear bumpers for my 66 that had two holes drilled in each one and were very pitted from exhaust gases for 850.00 total. They look fantastic and you would never know they once had holes for a trailer hitch.
Sidenote: i ordered some repro bumpers and they did not even line up with the body I also noted that they were much thinner than the original bumpers. I sent them back immediately.
Old Dec 11, 2010 | 03:10 PM
  #33
0Virginia Vettes
Former Vendor
We sell the 4 taillights for $235/set
Old Dec 11, 2010 | 03:53 PM
  #34
GCD1962's Avatar
GCD1962
$850 is almost double the going rate for 2 bumpers even with repairs.
Old Dec 11, 2010 | 04:25 PM
  #35
5thvet's Avatar
5thvet
Dick,
Is that a set of 2 or a set of 4 for $235?
Don
Old Dec 11, 2010 | 06:34 PM
  #36
Low Rider's Avatar
Low Rider
Default Plating
Although I have not used Advance Plating myself (have a local source that is excellent here in Michigan) I have seen several plating jobs from them on street rods in this area. Their work is outstanding and like other have said they are not cheep or fast but top quality chrome shops never are.
Old Dec 11, 2010 | 07:37 PM
  #37
Comp Cam 1's Avatar
Comp Cam 1
Banned Scam/Spammer
Another Vote for VA VETTES! Just sent them my C2 rear bumpers last week to be rechromed!
To Chrome questions...
Old Dec 12, 2010 | 08:00 AM
  #38
0Virginia Vettes
Former Vendor
Dick,
Don
That is for four taillights from Trim Products
Old Dec 12, 2010 | 08:02 AM
  #39
0Virginia Vettes
Former Vendor
That would be 1963-67 Taillights-- I thought I better clarify as the early lights are more
Old Dec 12, 2010 | 11:58 AM
  #40
5thvet's Avatar
5thvet
Mine is a 65 and that is a great price. You'll have my order.
Don
