decoding an 870 block
Old Aug 10, 2009 | 01:22 PM
bojangles's Avatar
bojangles
Default decoding an 870 block
I am interested in purchasing a 327 with the last 3 digits of the block # being '870'.
On one block the numbers on the left side are # xxxxx870 72 and on the right side G18
On the other block, the numbers on the left side are # xxxxx870 721 and on the right side is G18.
Can anyone help me with the decoding these numbers?
Old Aug 10, 2009 | 02:56 PM
JohnZ's Avatar
JohnZ
Assuming you're talking about the rear flange of the block (where the bellhousing bolts up), it should have 3782870 raised on the left side, and the G 1 8 on the right side is the raised casting date, inbetween two screw head impressions. Take another look at the casting date, as 870 blocks were only cast from '62-'65, and G 1 8 is July 1, 1968.
What's stamped on the machined pad at the front of the deck on the passenger side?
Old Aug 10, 2009 | 05:03 PM
CWPASADENA's Avatar
CWPASADENA
May be the "8" was mis read and it is really a "3" ? This would make more sense.
Chris CWPASADENA
Old Aug 11, 2009 | 12:54 PM
oldskydog's Avatar
oldskydog
The 721 is a Chevy II.
Old Aug 11, 2009 | 02:05 PM
JohnZ's Avatar
JohnZ
The "72" and "721" after the 3782870 are foundry pattern numbers.
Old Aug 11, 2009 | 10:31 PM
oldskydog's Avatar
oldskydog
OOPs,
He said he had two blocks and I was assuming (I know, don't assume) that he was referring to the last 3 digits of the casting numbers. 3790721 was a Chevy II casting for 65, the last 3 digits of which are usually found on the front of the block under the timing cover area and the rear under the bell housing area, along with the last 3 digits of other small blockcasting numbers that used the same front and rear patterns. I mistakenly thought that was what he was referring to.
To decoding an 870 block
