vapor lock??
Old Aug 12, 2009 | 05:29 PM
corvetterjk's Avatar
corvetterjk
Default vapor lock??
I was driving my 60 (stock 283 single wcfb) on a 90 degree day, car was running better than ever and suddenly I noticed a slight shutter and slowed for a traffic light, all of a sudden it just quit. Would not re start, just crank over, checked for spark--spark ok, ended up running the battery down, got a jump, still would not start---sat 20-30 minutes then fired off like nothing had happened--engine was running 180 degrees no puking or anything. Guys have said to block off the intake manifold heat ports under the carb. I have never had this happen before, any ideas, my girlfriend had to help push off the highway and now she wants me to sell it and buy a C-6!! Help!!
Old Aug 12, 2009 | 06:07 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
It could very well be fuel percolation....the symptoms you describe are typical. The accelerator pump can't get a good shot of fuel because its vapor instead of liquid and it takes a 10-20 min cool down to get restarted. I had to block off my intake manifold heat risers passages with a fuel injection gasket set and make up a set of 1/4" phenolic heat spacers to go between my dual quads and the intake manifold (you can't buy anything off-the-shelf for WCFBs) and that dropped my carb bowl temps 40-50 degrees as measured with my IR temp gun.
Old Aug 12, 2009 | 06:26 PM
GCD1962's Avatar
GCD1962
A quick way to release vapor lock is too losen the connection at the carb and then tightern it back up
Old Aug 12, 2009 | 08:09 PM
64Corvette's Avatar
64Corvette
Beware, when it is running the best that is when a problem is going to happen!
Old Aug 13, 2009 | 11:34 AM
corvetterjk
Thanks--I ordered a set of intake gaskets from Paragon with the block off plates attached, I will try that and make up a spacer for under the carb.
Old Aug 13, 2009 | 12:17 PM
MikeM's Avatar
MikeM
I would recommend you get rid of the girlfriend now. She sounds like she doesn't have much of a sense of humor and the next time it quit'
s you'll probably have to push the car by yourself while she takes a cab home.
Old Aug 13, 2009 | 05:13 PM
6T7L71CPE's Avatar
6T7L71CPE
I disagree!
Get the C6, C7, whatever, keep the girl, give me the '60. EVERYBODY'S HAPPY... ;{ )
I've got similar percolation issues.
Old Aug 13, 2009 | 06:51 PM
Frankie the Fink
Army
I used an old carb-to-manifold gasket as a template and made the spacer out of 1/4" Phenolic I got from McMaster (www.mcmaster.com)
Here are the specs: Part Number: 85315K164 Grade XX Garolite Sheet Black, 1/4" Thick, 24" X 24".
You will need carbide bits to work with this tough material.
Here is the article from John Hinkley I used to change the manifold gasket...lots of good tips including using a 1" dowel in the distributor hole to position the intake before assembly (attached). Consider wiring open your heat riser in the passenger side exhaust manifold too.
Be aware that the new intake manifold gaskets will MAKE YOUR CAR SOUND DIFFERENT! I didn't like the sound and wound up adding a balancer pipe between the exhausts to get the original harmony back (pic attached).
File Type: pdf
Old Aug 13, 2009 | 09:33 PM
Largecar's Avatar
Largecar
Cruising
Don't go out when it is that hot out! If you do keep your eyes peeled for one of those frame draggin S-10 pickups for road side help. Sounds like you got some good ideas to fix the problem. Good Luck
Old Aug 13, 2009 | 09:40 PM
Ron Miller's Avatar
Ron Miller
Here's another item you may wish to check out. I chased a similar problem for some time on my '66. It only happened when it was warm, but the temp gage wasn't showing all that hot. I rerouted lines, insulated lines, etc., and it turned out to be a weak fuel pump. I finally found the problem when the pump started leaking externally and had to be replaced.
Shazam!! After the pump was replaced I never had a hint of the problem again, went back to the original routing of the fuel lines, etc. Just something you may wish to check also!
Old Aug 14, 2009 | 06:35 AM
Frankie the Fink
Army
Worth a look but these WCFB's can operate off really low pump pressure...it usually high pressure that screws them up. If you have 4lb-5.5lb its plenty. The fuel line (on my 2X4 anyway) didn't go too near anything hot....it was strictly fuel percing in the carb bowls themselves..
To vapor lock??
