transmission
Old Aug 14, 2009 | 10:54 PM
jmschmit's Avatar
jmschmit
Default transmission
I tried the formula for checking between close and wide ratio. 4th gear at 1000rpm-23mph 1st at 23 mph tack reads 3050 rpm. 411 rear gears. did I do it wrong or what tranny do I have? Bill58.
Old Aug 15, 2009 | 01:53 AM
DansYellow66's Avatar
DansYellow66
I doubt the old factory tachs are accurate enough to make this work well. Plus there are probably some other pitfalls I can't even think of. I guess in theory a wide ratio should take 2-1/2 times as much rpm in first gear to maintain the same speed in fourth gear. But your example shows it doesn't work exactly like this in the real world.
But, I would guess wide ratio. 50/50 chance at being right.
Old Aug 15, 2009 | 04:24 PM
JohnFromVentura's Avatar
JohnFromVentura
Okay as an **** engineer here goes!
Running the numbers this is what I got:
(3050/4.11)(rev/min)(26"*pie/rev)(ft/12")=(23)(mi/hr)(hr/60min)(5280ft/mi)(1st Gear)
So:
1st Gear=(3050/4.11)(26*3.14/12)(60/23)(1/5280)
1st Gear =2.45 ~2.54
I think the math is correct but the equation might have a typo?
Old Aug 15, 2009 | 04:45 PM
Donald #31176's Avatar
Donald #31176
1000 RPM in 1st gear w. 4.11 & 26.5" diameter tire =
Wide box w. 2.54= 7.55 mph
Close Box w. 2.20= 8.719 mph
http://www.angelfire.com/fl/procrastination/rear.html
Old Aug 16, 2009 | 06:52 PM
Auto5's Avatar
Auto5
4th gear is 1:1 in both. Don #31176 is on the right track.
To transmission
