familiar sight?
Old Aug 16, 2009 | 08:48 PM
Allcoupedup's Avatar
Allcoupedup
Default familiar sight?
Notice something though -- NO RUST.
I was able to remove the rear trailing arms, control arms, spring, and half shafts and only had to cut ONE bolt - even the lower shock arms came out! My trailing arms bolts were easy with one exception - the body on the right side must be sagging because it was interfering with the bolt.
If I need to raise the body 1/16" to 1/8" can I do this by loosening the right two rear body mounts and gently jack the body?
THanks,
brian
Old Aug 16, 2009 | 09:50 PM
magicv8's Avatar
magicv8
I got mine out with a wrench 21 years ago, then installed stainless bolts, but I feel your pain.
