Spark Plug 43N please explain this
Old Aug 20, 2009 | 10:33 AM
revupL78's Avatar
revupL78
Default Spark Plug 43N please explain this
Long time ago I picked up a box of 8 ac delco 43N spark plugs for my 65L78. Although I do not run the TI ign (i run points) I was going to change plugs,,rotor etc.
I figured I would just use the 43N's but I never saw a plug like this. It is only threaded half way up ? Please explain
Old Aug 20, 2009 | 11:48 AM
MasterDave's Avatar
MasterDave
Moderator
In the fastener industry sometimes the threading machines mess up. I've seen bolts threaded wrong (left handed) and bolts with no threads. Just take 'em back and get new ones.
Old Aug 20, 2009 | 12:23 PM
Avispa's Avatar
Avispa
Those half threaded plugs should be ok. There is only about 3/8 inch thread engagement in the plug hole on an old big block head, and there seems to be that much thread. Those plugs seal using the metal ring on the thread base shoulder. 43N is a non-resistor plug, too. They're getting hard to find
Old Aug 20, 2009 | 12:53 PM
revupL78's Avatar
revupL78
Well Masterdave If I could go back it time and return them I am going buy up a whole buch of stuff and come back rich. I don't think they sold plugs like these in many many years. I nabbed of ebay bout 4-5 years ago.
I was just courious about the half thread vs. all thead
I actually put the laptop down and went to the books and found pre 1970 heads used the half thread
Old Aug 20, 2009 | 03:42 PM
MasterDave's Avatar
MasterDave
Moderator
:o Made it almost the whole year without making an error!!
Old Aug 20, 2009 | 05:02 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Ac 43n plugs
AC 43N & R43N and the whole series of "N" plugs have always been threaded only half way up the OD. The R43XLS, which is the extended nose version is threaded all the way up. The threads in your heads is at the bottom of the hole and matches up nicely with the 43N or any other 1/2 threaded plug. You can use either 1/2 threaded or full threaded versions with no problem.
RON
Old Aug 20, 2009 | 08:28 PM
StingU2's Avatar
StingU2
RON
there is nothing wrong with placing the AC 43N in your heads... they will be just fine.
Old Aug 20, 2009 | 08:51 PM
Trophy Blue's Avatar
Trophy Blue
Old Aug 20, 2009 | 09:47 PM
Laser Red's Avatar
Laser Red
Default 43 N plugs
I ran these in my L72 with early fouling potential---due to the fact they are a cold running plug. R44's are hotter my enging builder told me. Might add I have roller rockers in the solid lifter mill.
Old Aug 20, 2009 | 11:46 PM
Ironcross's Avatar
Ironcross
Thats a early BB plug that due to its number 3 is a cold plug that is good for racing but not for the street. As noted above the AC replacement is the XLS plugs. I believe older Caddies and I know for sure Chrysler Hemis used them.
Old Aug 21, 2009 | 07:27 AM
pltmgr's Avatar
pltmgr
Default spark plug
I used 43XLS plugs back in the day in my 68 L89 that was my commuter and they fouled within 500 miles.
Old Jun 5, 2015 | 11:03 PM
Ironcross's Avatar
Ironcross
R45XLS replaced the N43....which is way too cold for the street.....Only TWO plugs will fit the BB head that you will be able to buy over the counter....R45XLS which is a 3/4 reach and the R45TS which has a tapered seat.and that's all there is....simple , Right
Spark plugs don't know what ignition your using and could care less if they could think.....And yes, .035 is the best gap for ALL plugs on all ignitions
You never saw the plug {43N} because its obselete..
Old Jun 6, 2015 | 07:48 PM
Randy G.'s Avatar
Randy G.
6 year old thread?
To Spark Plug 43N please explain this
