Master cylinder bleeding
Thanks, Ron
Dennis
each caliper. All was good, good pedal, stopped fine and straight.
Last weekend on the way to a show I had to do hard stop at a light
to avoid loosing the other two cars behind me.
When I left the show at the end of the day, I had little or no brakes.
Pedal was almost on the floor. Limped it home, master cylinder was
full.
I have less than five hundred miles on it.
I ordered a new one from the partsladi, it came with the warning
label,
"Warning due to the oem seal design on this cylinder, you should not attempt to bench bleed prior to installation. This item should be pressure bled or vacuum bled only."
Your mileage may vary.
I ignored the instruction and bench bled it anyway as I don't have a pressure bleeder and I don't care for the vacuum bleed method. No problem here but I don't know what the negative consequeces of bench bleeding might have been but I did it anyway.
I ignored the instruction and bench bled it anyway as I don't have a pressure bleeder and I don't care for the vacuum bleed method. No problem here but I don't know what the negative consequeces of bench bleeding might have been.
