Leaking M-20
Old Aug 24, 2009 | 10:25 PM
Jackfit's Avatar
Jackfit
Default Leaking M-20
Hi,
Never had a problem until I put in new back up light bracket.
As I am restoring my 66 roadster, L79, I thought that after almost 40 years, (put in a Hurst in 1970 ) and broke the back up light switch, it was time to put in new switch.
Had to take out two bolts on side cover to attach switch. (30 lbs torque) Has been leaking since. Just a little, but after fixing my engine (Oil Pressure Saga thread) , oil on the ground makes my crazy.
Any suggestions on stopping it. Can I change the gasket without taking out tranny? Can I put something on the bolts?
Can over filling tranny cause leaking ?
Jack
Old Aug 24, 2009 | 11:36 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Trans leak
Pull those 2 bolts out again, clean the 2 bolts, and then reinstall them with a coating of permatex #2 sealer or some equivalent. I guess that you could also use silicone gasket maker (blue snot) if you couldn't find anything else. I don't think that removing those 2 bolts would have ruined the cover gasket, but if the leak continues, the side cover can be removed with the trans in the car. Are you sure of the torque ??? They're only 5/16" bolts--30 foot pounds sounds a little high--The chassis overhaul manual states 20 foot pounds--I hope you didn't strip the threads in the aluminum case.
RON
Old Aug 25, 2009 | 12:13 AM
LT1driver's Avatar
LT1driver
did you put car in a "hearst" sorry couldn't resist...it is "hurst"
agree on the permatex #2, use some grey gasket maker if you remove cover, similar to what toyota uses on oil pans when not using a gasket, works great, autozone has it. good luck with the leak.
Old Aug 25, 2009 | 06:35 AM
Jackfit's Avatar
Jackfit
Default Right 20 lbs
RON
Right 20 lbs. I could not remember last night. But did 20 when putting bolts back.
Jack
Old Aug 25, 2009 | 06:38 AM
Jackfit's Avatar
Jackfit
Default It might be mine
Aren't we all going to our graves in our cars?
Thanks I will try the easy fix first.
Jack
Old Sep 4, 2009 | 07:33 AM
Jackfit's Avatar
Jackfit
Default Bolts not leaking seems to be lip seal on shifter shaft
RON
Hi Ron,
Cleaned bolts and put Permatex sealer on all of them.. 20 lbs torque. Still leaks. Found leak. It seems to be leaking from 1 and 2 gear shifter shaft. My chassis manual shows a lip seal in the side cover. Can that seal be replaced without removing side cover? It seems pressed into side cover opening where shaft comes through cover.
Jack
Old Sep 4, 2009 | 08:46 AM
muncieman's Avatar
muncieman
Originally Posted by Jackfit
Hi Ron,
Jack
That would be hard to do, you need to pry the old seal out then set the new seal with the shift shaft in the way. To make it worst, it's in a very tight place. Taking the side cover off with the trans in the car is also very difficult. I would remove the trans and do it on the bench but I'm sure there will be as many opinions on this as there are days in the year.
Try putting the side cover on, the forks stick out about 5 plus inches, is there enough room to do this???? I don't think so.
Also if you attempt to do this, shift the trans into second, makes it a lot easier.
Old Sep 4, 2009 | 11:37 AM
Auto5's Avatar
Auto5
Replacing the shift shaft seals pretty much involves everything but the physical removal of the tranny but it can be done while it's still in the tunnel.
Old Sep 4, 2009 | 12:15 PM
muncieman's Avatar
muncieman
Default Let's talk about this.
If you try this in the car, the shifter will need to come off, bolts out the trans to bell housing, bolts removed from the trans mount.
You will need to rotate the trans so the side cover is facing down. Remove the side cover bolts and catch all the gear oil as it come out all at once, unless you have a drain plug.
Now you can remove the shift shafts, remove the old seals and replace them. If you don't have them, your local parts store will look at you like your nuts when you ask for them.
I have them, $1 each. Now you need to clean up the case for the side cover gasket. I also have those.
There is one thing that has not been mentioned, the side covers have been known to wear and get sloppy on the fit of the shift shafts, replacing the seal may not fix the problem.
Now, tack the gasket to the side cover, shift the trans into second gear, put the cover on. Spin her back into position and button it up.
Don't forget to get some GL-4 gear oil or the MT-90 syn by RED LINE.
Old Sep 4, 2009 | 02:22 PM
Jackfit's Avatar
Jackfit
Default Thank you for your offer
I will contact you when I get ready to take apart the car again. I am going to live with it while the weather is great here in Maine.
I was at Carl Hinkson's camp today, took him for a first ride in car with his engine rebuild, and mentioned the leak. He said that there is a possibility that my transmission may vented and that it may be blocked.
When I opened the drain plug when this leak first appeared , the oil squirted out as if it were under pressure. Does my M-20 have a vent? and if it were blocked could the oil find the least resistance in the shaft seal.
Jack
Old Sep 4, 2009 | 09:38 PM
muncieman's Avatar
muncieman
Jack
No stock muncie has a vent and normally would never need one. If bubba has been in there and blocked the oil drain back hole uunder the front bearing or the hole in the input is clogged up, it is possible the trans may be building pressure, kind of remote in a stock muncie.
Old Sep 4, 2009 | 10:07 PM
skids's Avatar
skids
Yes the side covers do wear. I fixed my leaky cover. Replaced it with 5speeds.com roller bearing side cover. Super happy with it!
Old Sep 4, 2009 | 11:00 PM
Jackfit's Avatar
Jackfit
Default Sounds like I have a leaky cover
I will take on the problem next month. This month, just burning up gas , enjoying the ride.
I will ask for more detailed help, when it is 3 am and I am on my back under the car, with oil dripping on my face.
Thanks everyone for the advice.
Jack
Old Sep 4, 2009 | 11:14 PM
Johnny 66's Avatar
Johnny 66
Jackfit, what part of Maine are you in? I lived in Brunswick for 4 and then later 2 years. Made it to the Owl's Head corvette show in 2007.
Didnt have my '66 then, was just a spectator.
Perfect time of year to be cruisin' in Maine!!
Old Sep 5, 2009 | 06:08 AM
Jackfit's Avatar
Jackfit
Default Cape Elizabeth
I live just outside of Portland, and the weather that last few weeks has been great.
What a pain to have a leak after almost all the hard work on the engine and restoration is done,
Jack
Old Sep 5, 2009 | 07:56 AM
muncieman's Avatar
muncieman
That would be a Auto-Gear roller bearing side cover which uses a newer and stonger shift shaft, stock shift shaft is to small for the new side cover.
Old Sep 5, 2009 | 08:18 PM
skids's Avatar
skids
OOPS! Yeah,that's the one.
To Leaking M-20
Old Sep 6, 2009 | 10:45 AM
Jackfit's Avatar
Jackfit
Default Lets talk about this
Thanks for advice. Now let me get this straight, Drain tranny, Unbolt linkage, No problem turning tranny. (yea sure) . Once that is done,
unbolt cover. Does cover come off with shift shafts ? Let me know what happens once I take cove off. I just replace seals this time I think, rather than change cover, Unless cover has real wear.
Any help on what to do when I have cover off will help. I will ask you for seal etc, later
Jack
Old Sep 6, 2009 | 01:39 PM
muncieman's Avatar
muncieman
Jack
Turning the trans sideways will be a lot of fun, but it should work.
The side cover will come off with the shift shafts and forks along with all the oil!!!
Old Sep 6, 2009 | 02:55 PM
rongold's Avatar
rongold
Default Trans Side Cover
Put a floor jack and a 2X4 under the engine oil pan to slightly lift everything up while you spin the trans. Just don't let the trans slip backwards. You probably don't have to spin it more than 45 degrees to get enough room to pull the cover. Make sure the trans is in 2nd gear to allow the 1-2 fork to be removed with the cover. After you get the cover off, take a good look at how the lockout mechanism works and pull the 2 forks. Then remove the lockout spring. Swing the lockout levers out of the way, and you can then remove the 2 shifter shafts by just pulling them out. Remember which is which--I seem to remember that they are different and need to go back in the same location. With the shafts out, just take a screwdriver and pry the seals out. Be careful not to scratch the bores. Install the 2 new seals and then the shafts. Lube the seals with gear oil before you insert the 2 shafts. Reinstall the lockout spring and then the 2 forks while holding the lockout levers up. Make sure that the 1-2 shaft is in the second gear (forward) position. Clean the case and side cover surfaces and reinstall the cover along with a new gasket. Spin the trans upright and reinstall everything. Don't forget to refill the trans.
RON
P.S. I don't think you will be able to spin the trans while it is in gear unless you have the rear wheels off the ground. You will have to put it into 2nd after you spin it. Leave the 1-2 lever on to accomplish this, and remove it to pull the shaft out. After you have the cover back on, reinstall the 1-2 lever and put the trans in neutral to spin the trans vertical again. Hope I didn't confuse you.
