Thermostat Question
Old Aug 26, 2009 | 01:51 PM
C Ray's Avatar
C Ray
Default Thermostat Question
I have a 67 corvette with a 327/350 and I am replacing the thermostat. My original is marked 170 and I have the parts book for that year and it says it is a 170 degree thermostat. Since that doesn't seem to be made anymore, the choices are 160 degrees or 180 degrees. Every manufacturer seems to recommend the 180 instead of the 160. Any idea why? Keeping the cars cool as they get older would seem to be a typical problem so I would have guessed they would have suggested the 160 degree replacement? Just curious what the rational is?
Old Aug 26, 2009 | 02:12 PM
Powershift's Avatar
Powershift
Recommend that you install the 180 F thermostat. That is what most of us have in our cars.....especially if you live up north. I run it in my 327/350 HP car here in south Louisiana without issue.
The 180 F thermostat will help ensure that your oil temp is always high enough to boil off any condensation/moisture. That may not happen with the 160 F thermostat in cooler weather.
Larry
Old Aug 26, 2009 | 02:20 PM
JohnZ's Avatar
JohnZ
The thermostat has no effect on maximum engine operating temperature - it only serves to provide rapid warmup (to minimize internal wear) and controls the minimum temperature (as in winter, to ensure that the heater performs effectively). Maximum operating temperature is a function of the overall condition of the cooling system.
Old Aug 26, 2009 | 02:24 PM
magicv8's Avatar
magicv8
NAPA has 170° F tstats.
I got one for my 66
Old Aug 26, 2009 | 04:35 PM
Matt Gruber's Avatar
Matt Gruber
john- i think your thoughts got jumbled up there
Old Aug 26, 2009 | 04:47 PM
w1ctc's Avatar
w1ctc
But wait, if the cooling system has more capacity than needed. The thermostat will close enough to maintain the temp thereby controlling the max temp. With enough cooling capacity, the temp will never rise much above the thermostat design temp. Keeping in mind that the stat starts to open at the design temp and becomes fully open at some higher value.
Old Aug 26, 2009 | 04:48 PM
BarryK's Avatar
BarryK
why do you say that?
What did John say that is incorrect?
t-stat DO only control minimum operating temps, not the maximum
Old Aug 26, 2009 | 04:54 PM
BarryK's Avatar
BarryK
true, but if the cooling system has enough capacity to keep the operating temps at the t-stat rated temp it's than the reason it's kept there is because of the COOLING SYSTEM CAPACITY.
The MINIMUM operating temp is controlled by the t-stat since it stays close until the coolant in the engine block reaches the t-stat rated temp than it opens up therefore controlling the minimum operating temp.
After that the motor can operate at t-stat rated temp or higher - all based on the capacity of the system, not the t-stat.
Say the system has low cooling capacity because of radiator clogged with years of mineral deposits. The operating temp could easily go higher and higher until it overheats - the t-stat will do nothing to stop it or control it
Old Aug 26, 2009 | 04:56 PM
magicv8's Avatar
magicv8
johnz stated it correctly.
Also, if the cooling system has more than enough capacity to handle the engine and accessories such as A-C at all speeds and ambient air temps, then the engine temp should hover just above the tstat opening temp, which is what mine does.
Old Aug 26, 2009 | 04:57 PM
Jims66's Avatar
Jims66
Having said that I have a 160 in my 327/350 because the day I bought it there were only 160s and 195s in the store. The popular 180 was sold out. I've had that 160 thermostat in my car ever since...... about 20 years now. I do drive in the winter but usually nice long rides so it's a moot point anyway as the motor runs long enough to get fully warmed up. Most of my driving is in the warmer weather anyway.
Old Aug 26, 2009 | 05:01 PM
Silverblue64's Avatar
Silverblue64
Active Streak: 90 Days
I got one for my 66
Do you happen to remember what the NAPA part number is for the
170* thermostats?
I searched on their site but came up empty handed.
Old Aug 26, 2009 | 05:39 PM
magicv8's Avatar
magicv8
10220957, made by AC Delco
NAPA can no longer cross reference it, but my Chevy dealer just ordered a spare for me - it will arrive in 3 days.
Old Aug 26, 2009 | 05:49 PM
Silverblue64
Thanks for the information
Old Aug 26, 2009 | 08:37 PM
65tripleblack's Avatar
65tripleblack
The radiator does NOT have the capacity to keep the engine at 160, 170, or even 180 degrees in anything more than, say, 70 degrees ambient. Newer cars have much more capacity, older cars do not. Especially C2s because or limited space.
If you remove the rad support and replace it with one from a 1967 427, and use a radiator from a 1967 427 in your SBC, you STILL would not have enough cooling capacity to keep the coolant below about 190 degrees on a moderately hot day.
Don't believe me? Try this as an experiment. Remove the thermostat, and see if it makes any difference, at all, in your engine's coolant temp during the summer. Now, if you drive around without a thermostat in the winter (not recommended) then your engine's coolant WILL be too cold.
Old Aug 26, 2009 | 08:47 PM
SupremeDeluxe's Avatar
SupremeDeluxe
John is, of course, correct. The thermostat only regulates MINIMUM engine operating temperature.
I would use a Robertshaw or Mr. Gasket 180 high perf. thermostat. Robertshaw P/N is 330-180 and Mr. Gasket is #4364.
On a side note, I was very disappointed that my recently acquired 67 427 would not run under 195 degrees while all my other Corvettes have run 180 without difficulty. It never occurred to me that the car had a 195 stat in it until I pulled the stat out for clearance to remove the temp sender. It's a 195. Had NAPA check their book when I was there yesterday buying some stuff for the Caddy, and sure enough 195 is what their guide lists as a replacement. No wonder!
Old Aug 26, 2009 | 09:01 PM
magicv8's Avatar
magicv8
"The radiator" may not, but my aluminum Griffin BB rad can hold the engine at 170-180 even on 100F days with A-C running - idling in city traffic or blasting up a mountain at 85mph (which is the more difficult task for the rad). My electric puller fan handles city idling with A-C, but it takes air flow management to do it at high speed and high load (up mountain).
I have heard that a factory style sb rad can do it too, but the owners I know with A-C cars use auxilliary electric pusher fans to assist with city rad cooling.
Old Aug 26, 2009 | 10:09 PM
w1ctc's Avatar
w1ctc
Ok, I concede that the stat controls min temp. On the other hand, sitting in the car with a 180 on the gauge and then putting in a 195 stat. It would sure look like my max temp went up even though it is the new min.
To Thermostat Question
Old Aug 27, 2009 | 06:13 AM
Matt Gruber
t-stat controls the minimum maximum.
the OP asked a GREAT question imo. paraphrased "Does an old car last longer if it runs cooler"
That is debatable of course.
I say, quite the opposite; it wears faster if it runs cooler. It is easy to make it run say, 195F and make it last longer, but that is counter-intituitive to many, i suspect.
Old Aug 27, 2009 | 06:35 AM
BarryK's Avatar
BarryK
I disagree
Even on very hot days around here (in the 90's) mine stays right at 180-185º no matter city/traffic or highway.
In fact it was right about 90º or a little more yesterday and fairly humid making it a pretty uncomfortable day. I had meeting about an hour away from me up in King of Prussia, Pa so I drove the '65. no matter if I was in traffic or I was doing extended fast cruising (about 75-90mph on the higway) my temp never went above 185.
I have Dewitts rad in my car that is approx 12 years old and it keeps the temps down just fine.
Old Aug 27, 2009 | 06:38 AM
BarryK's Avatar
BarryK
I think you are reading it wrong. He doesn't say that
