Electircal Issue (Insight Needed)
My C2 is a complete reno with new everything. For the last year, she's been running great and all is working. Last weekend, we were at a cruz in until late evening and something odd started happening. When I turned the headlights on, they work, but dash and lights are all very dim. The dash volt meter shows a large draw on the battery system as well. Turn the lights off, and all is back to normal. This would lead me to believe I have a short or a bad light switch (although its new too). To add to the confusion, this is where it gets strange. Even with lights off now, when I'm driving down the road with the stereo on, and put on a turn signal, the amp on the stereo (separate on the back deck near woofers) goes out. The blinkers work fine, but power drop is obvious. I think the amp just doesn't have enough power to pull, so it shuts down. This has me perplexed as to where to look for the short??? Seems like it might be across several circuts. Seems like a ground issue, but every area I check, all looks OK. If you have any suggestions as to where to look, or proceedure to check, I'd love to hear it. I'm about to pull the dash, and we all know how fun that is!
For added insight, note that I replaced the alternator, and voltage regulator (with a high end one vs standard) last summer. While it works great all last summer, is it possible there's something there?
I hope someone can offer some insight as to where to start. Pull fuses one at a time? Any thoughts appreciated.
Emaiil me at: jim@janicekmedia.com
Much appreciation to all you wizards who've always been so helpful to me.
Sincerely, jim Janicek
Diming of Headlights often is caused by poor Ground Returns. Keep us informed. Al W.
Before you go disconnecting stuff, put a voltmeter on the battery and see what it reads at idle and when you rev the engine. With the lights and stereo turned off, If it doesn't go over ~13.5 volts when you rev it up, you're not charging and need to look at the alt/regulator/their wiring again.
Recent changes I've made.
1) Added an on/off switch to the positive side of the battery between the battery and starter.
2) Delco Remy (new Alt.) 3 pole plug w/neg pole ground. 66 amp / 12v.
3) Battery (new) Optima red top 12v gel cell.
4) Voltage Regulator (new) Niehoff *Is it possible I got the wrong one?
5) Stereo Amp. (cheap) Visonik V2208 110w 2 channels.
Is it possible I put in the wrong distributor or vr ?
Thanks again.
JJ
JJ
JJ
If you pull your alternatior off, most auto parts stores can check it usually for free. That's just a couple bolts and easiest thing to try first.
"Recent changes I've made.
1) Added an on/off switch to the positive side of the battery between the battery and starter."
Is the switch wire 6 ga.? Can the switch handle a 100A kick back of the starter? If the switch is breaking down it will act as a load on the battery
Yes, the VR could be the culpret or it could be both (one will often take the other out on its death), or the wiring between them and the battery.
I just figured that the alt was the easiest thing to try first. It is a PITA to pull a passenger-side the battery out of a C2. If the auto parts store can check the VR and you are comfortable that you can properly reconnect it when you put it back, take that too.
Best, Jim
Best, Jim
Sounds like you got it fixed. Just for grinns, now check the voltage at the battery when you rev the engine and tell us what it is.
