Reusing leaf spring U bolts
Old Sep 5, 2009 | 06:24 PM
skids's Avatar
skids
Default Reusing leaf spring U bolts
Is it a bad idea? I've read not to reuse them, due to the rolled threads?? Anyway, the ones in question have only been on the car, a 62, about a month. Considering what could happen, I know it would be wise to put new ones on again, but I thought I would get some input anyways.
Old Sep 5, 2009 | 06:39 PM
Plasticman's Avatar
Plasticman
Have been re-using U bolts forever, and have never seen an issue.
And what is wrong with rolled threads (which are stronger than cut threads due to the lack of stress risers at the root of the threads)?
Plasticman
Old Sep 6, 2009 | 09:01 PM
Pilot Dan's Avatar
Pilot Dan
Plasticman
Unless there is an issue with the threads or the bolts are severely rusted, no reason not to re-use them. Of course, a new set with hardware is only around $40, so if that will help you sleep better.....the choice is yours. Pilot Dan
To Reusing leaf spring U bolts
