Petronix
Car runs like a champ again. I was of the Mindset that the Petronix would just Crap out if it was bad. Not So! I'm passing this Info along for General knowledge. Thanks for Listening! Al W.
When you use the Pertronix module in the distributor, the module drops about 1 volt more.
Therefore, you now only have about 5 volts across the coil primary when the Pertronix module is switched on.
What you have is:
1) 6 volts dropped across the resistor.
2) 1 volt dropped across the Pertronix ignition module when it is switched on.
3) That is 12 - 7 = 5 volts for the coil.
Therefore, you have less voltage across the ignition coil primary with the Pertronix.
By using the Pertronix ignition coil, it is designed to work with the voltage drop of the Pertronix module.
Tom Piper
Here's something I developed a few years ago to help take the mystery out of the instructions that come with the Pertronix. This was specifically drawn for my 65. I'm working on a 62/earlier version with different wire colors.
Their original unit had the magnet ring (1181) and later they added the module that picked up off of the point cam (1181LSC). I prefer, and have stayed with, the original 1181 and have had ZERO problems (and no customer complaints) with it. Although, I must admit that the 1181 (with the magnet ring) is considerably more time consuming to install because it requires removal of the distributor for installing shims between the bottom of the dist housing and drive gear. Also, I have discovered that MOST Corvette tach drive distributors DO NOT have the huge gap at the drive gear that NON-tach drive distributors have (regular pass car distributors). With the magnet ring shimmed for a .010-.020 air gap between the ring and the top of the module, they work as advertised.
The PerTronix, and other similar electronic conversion units, IS NOT a super duper, double whamy fire breathing ignition system for hard core racing applications. But, it is an EXCELLENT conversion which eliminates the disadvantages of points/condenser, plus, it is entirely contained inside the cap with no external boxes to detract from the stock appearance. With their conversion unit and coil, they advertise up to 40,000volts. Maybe. But for sure, because of the inherent design, you're going to get more fire to the plugs than with points. And NO, the PerTronix coil (or any other aftermarket coil) does not look exactly like the stock Delco coil--------------------but with ignition shielding installed, no one can tell!
Tom Parsons
I put it on and shimmed the distributor gear and set the gap as required.
I had a low-speed miss that I could not get rid of, until I went back to points.
With an oscilloscope, I checked the voltage drop at the coil with and without the Pertronix -- both with the resistor in place.
The voltage drop across the coil is greater with the points.
Tom Piper
Tom Piper
What coil do you plan to run? I don't know about the Ignitor I, but the Ignitor II when used with the Pertronix Flamethrower coil, should be connected to bypass the ballast resistor.
