Negative offset wheels?
Old Sep 10, 2009 | 06:51 PM
6T7L71CPE's Avatar
6T7L71CPE
Default Negative offset wheels?
My Aluminum slots are 7" with a 3" backspace, so that's a -1" offset. I know the suspension is designed for basically 0" offset, therefore tracking on uneven roads and the added stress on the bearings can be a problem. I'd imagine some of you have similar or greater offsets. Just how detrimental is this for a weekend driver?
Old Sep 10, 2009 | 10:45 PM
3JsVette's Avatar
3JsVette
I wouldn't worry about it. All the "flared" C3s run with a lot more offset than that. Even a stock C3 uses a 8" wheel with a 4" backspace.
Old Sep 11, 2009 | 12:10 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
That's only 1/2" offset. Don't loose any sleep over it. I used to race with a 10" wheel with 3" offset, 12 " slicks lap after lap.
Old Sep 11, 2009 | 09:07 AM
mashinter's Avatar
mashinter
I had wheel bearings fail on a '59 (roller bearings) because I had wheels that sat more outboard.
Chevy enlarged the spindles and bearings with the 8 inch wheels introduced in 1969; the 8 inch wheels moved the wheel more outboard.
I'd just keep an eye on them. You're increasing the load on the outer bearing. I remember the inner race being the weak link, so once in a while pull the outer bearing, make sure it's well lubed, and feel for roughness by rotating the bearing. I'd do that before a long trip. Bearings will fail with lots of warning, but you have to be alert for the warning signs (hard lesson learned!)
To Negative offset wheels?
