U-bolt U-joint torque
Old Sep 11, 2009 | 07:58 PM
Jimbad's Avatar
Jimbad
St. Jude Donor '06-'09-'10-'11
Default U-bolt U-joint torque
Hi, All,
According to the AIM for my '66, the nut that fastens the U-bolt that holds the universal joint to the differential should be torqued 55-75 lbs.ft..
My question is: how in the world does one get a torque wrench on that nut? I have tried three t. wrenches and have moved the half-shaft around but all to no avail. If it can't be torqued, then how will I know that I have tightened the nut properly?
Thanks,
Jim
Old Sep 11, 2009 | 08:21 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default U-bolt Torque
I haven't taken mine apart for over 30 years, so I can't tell you how it's done, but 55-75 foot pounds sounds awfully high for a 5/16 thread. Check that spec again, or when you finally figure out how to do it, you might end up with a stripped U-bolt.
RON
Old Sep 11, 2009 | 08:36 PM
62Jeff's Avatar
62Jeff
My 65 AIM, UPS 4 sheet A2, shows the torque at 12-15 lbs-ft.
It is part of the U-bolt assembly, parts 8, 9, and 10. 8 is the U-bolt, 9 is the lock washer, and 10 is the nut which has torque footnote "5" associated with it. Footnote 5 indicates 12-15 lbs-ft
Old Sep 11, 2009 | 08:40 PM
rongold's Avatar
rongold
I just looked at my 66 & 67 AIM's and the 55-75 foot pound torque is for nut # 12, which is your lug nut. The spec for nut #10 is unclear, as the triangle next to #10 is smudged in both my 66 & 67 AIM's. I really think that the correct torque is #4, which is 15-20 foot pounds.
RON
Old Sep 11, 2009 | 09:12 PM
Jimbad's Avatar
Jimbad
Thanks Ron and Jeff. Jeff, unlike your AIM my '66 book shows, if I am reading it correctly, that the U-bolt is#6, the lock washer is #5 and the nut #4 (I was nowhere close to #12!). My AIM is so blurry that small numbers are very difficult to read. I believe that you guys are correct with the low value that you sent so I'm going with that.
Still, no one has told me how to get a torque wrench on there, or does the low lbs.ft. value make an accurate setting not important?
Thanks again,
Jim
Old Sep 11, 2009 | 09:34 PM
62Jeff's Avatar
62Jeff
RON
On mine, the triangled "4" is for the diff plug at 15-20. I have a circled "4" which is associated with a Dec 64 revision comment.
Jimbad for such a low torque number, I'd just snug it up by feel.
Old Sep 12, 2009 | 09:48 AM
lovevettes's Avatar
lovevettes
How about a crowfoot socket?
Old Sep 12, 2009 | 10:42 AM
bweaver999's Avatar
bweaver999
That's what I used:
http://www.sears.com/shc/s/search_10...owfoot&x=0&y=0
Old Sep 12, 2009 | 12:36 PM
Powershift's Avatar
Powershift
Jim:
I have always tightened up with a box end wrench by hand and never had a problem (last 40 years or so).
However, if you want to torque, use a crowsfoot like a few others mentioned OR make yourself a "custom" extention from a box end wrench. Cut it in half and weld on a 3/8 " or 1/2 " socket (or part of a socket). I did this (custom extention) for torqueing my aluminum intake manifold bolts. Reduce torque value a few ft-lbs or use the lower value in the range.
For your U-joint application, I would just carefully tighten by hand and call it done.
Larry
Old Sep 12, 2009 | 12:41 PM
62Jeff's Avatar
62Jeff
Since a crow's foot moves the fastener location away from the pivot point for the torque wrench mechanism, won't the short distance between the two act as a lever to provide a higher torque reading at the fastener, than is indicated by the wrench?
Old Sep 12, 2009 | 01:06 PM
Jimbad's Avatar
Jimbad
Thanks for all of the suggestions. As usual, this Forum provides a lot of info.
Jim
Old Sep 12, 2009 | 01:56 PM
JohnZ's Avatar
JohnZ
The '66 A.I.M. (UPC 4, sheet A2) shows the nut as item #10, and the torque symbol adjacent to it in the triangle is "5", which is 12-16 ft-lbs. at the bottom of the page.
Old Sep 12, 2009 | 01:59 PM
Powershift's Avatar
Powershift
Yes it will. You have to correct for this. However, it often is very slight and doesn't matter much.
If the extention is over a few inches, I do the calculation and correct (reduce) the torque wrench set value.
To U-bolt U-joint torque
