Temperature Gauge Question
Old Sep 13, 2009 | 11:29 AM
babbah's Avatar
babbah
Default Temperature Gauge Question
Can anyone tell me what is the correct temperature in degrees at the first line (at around 10 o'clock) before the next middle line 210 mark on a 1967 Temperature gauge? Is it 180 degrees? Thank You -
Old Sep 13, 2009 | 11:39 AM
62Jeff's Avatar
62Jeff
I don't know for sure from any design standpoint, but the consensus has been that those marks represent even divisions on the gauge.
With the lowest mark indicating 100, and the middle mark 210, that's 110 degrees of range. The mark in the middle thus would be 155 (100 + 110/2) assuming the gauge is linear as we suspect.
Old Sep 13, 2009 | 11:52 AM
bweaver999's Avatar
bweaver999
This thread may explain it:
http://forums.corvetteforum.com/c1-a...mp-gauges.html
Mine is right on the line at 180.
Old Sep 13, 2009 | 11:56 AM
62Jeff's Avatar
62Jeff
So yours is at 180 when at the mark between 100 and 210? Interesting.
Old Sep 13, 2009 | 12:01 PM
5thvet's Avatar
5thvet
Sounds like a 65 Gauge.
Old Sep 13, 2009 | 12:12 PM
62Jeff's Avatar
62Jeff
A 65 gauge has 180 printed on the dial, at the center point of the range.
Old Sep 13, 2009 | 12:20 PM
5thvet's Avatar
5thvet
that's why I said it sounded like a 65 gauge when he said " right on the line at 180"
Old Sep 13, 2009 | 12:28 PM
bweaver999's Avatar
bweaver999
From an old post, pics:
http://forums.corvetteforum.com/1561763387-post9.html
Old Sep 13, 2009 | 12:31 PM
62Jeff's Avatar
62Jeff
Perfect, clears it right up.
Old Sep 13, 2009 | 12:39 PM
CWPASADENA's Avatar
CWPASADENA
The first mark on a '67 gauge is "Warm, but not too hot".
The 210 Mark is "OK but you do not want it to get much hotter",
The third Mark is "You better get this thing cooled off"
And the last mark is "Bail out, She's Gonna Blow"
Chris, CWPASADENA
Old Sep 13, 2009 | 07:37 PM
jdk971's Avatar
jdk971
my 66 is 180 at that mark in the photo above also. jim
Old Sep 29, 2009 | 08:36 PM
C Ray's Avatar
C Ray
Looking at the face of the gauge it would seem to be very non-linear. On the left you go from 100 to 210 but in the same space on the right you go from 210 to 250. To approximate the middle mark on the left you can ratio total gauge lower half to total gauge upper half and compare that to left half lower portion and left half upper portion. With that the middle mark on the left figures out to be about 180 degrees. My original 170 degree thermostat seems to settle just slightly over the middle mark on the left so (while not exact) that sort of confirms the calibration.
To Temperature Gauge Question
