Differential Front Mount
Old Sep 17, 2009 | 06:26 PM
hzz's Avatar
hzz
Default Differential Front Mount
Do I have these cushions and washers in the correct order?
Something doesn't seem right to me because the lower cushion presses against the metal insert of the upper cushion.
You can't see it in the picture but I have the large flat washer then the lock washer below the lower cushion.
Old Sep 17, 2009 | 06:56 PM
PinkVetteLady's Avatar
PinkVetteLady
You need to turn the bigger cushion on the right around. The metal sleeve from the one that goes on top through the frame seats against the metal in the bigger cushion.
Old Sep 17, 2009 | 09:11 PM
hzz's Avatar
hzz
Hard to tell from picture but the metal on the bigger cushion is facing left towards the sleeve.
Old Sep 17, 2009 | 09:19 PM
Corbrastang's Avatar
Corbrastang
Sleeve sits on top and passes through the hole.
Smaller cushion is on top with smaller washer
Bolt passes through from the top.
Larger cushion on bottom with large washer,lock washer, and nut
Old Sep 17, 2009 | 09:49 PM
hzz's Avatar
hzz
That's what I have.
Old Sep 18, 2009 | 08:43 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Diff. mount
You may want to rethink using the poly mount on the rear. I had to remove mine because it was not thick enough. The poly mount allowed the diff. to sit too high. The result was that my rear U-joint hit the body of the car while a passenger was riding in the car. Jerry
Old Sep 18, 2009 | 10:22 AM
GTR1999's Avatar
GTR1999
I agree, I would not use a poly snubber.
Old Sep 18, 2009 | 11:30 AM
Corbrastang
Ditch the poly bushing. I tried to use it on two cars and it caused some serious rub.
Old Sep 18, 2009 | 12:57 PM
hzz's Avatar
hzz
I didn't even know they were poly.
I had ordered rubber......probably a stupid question but how do you tell the difference?
Old Sep 18, 2009 | 07:06 PM
Corbrastang
poly is hard as a rock and will not compress or wrinkle
Old Sep 18, 2009 | 07:11 PM
PinkVetteLady
That doesn't look like poly to me by looking at the upper cushion you can see that it's rubber. The rubber ones lately from ZIP have looked just like the one in the picture. I have noticed that the ones from ZIP are more stiff and last. The ones from LIC seem to be made out of a softer rubber and have not held up as good.
Old Sep 18, 2009 | 08:26 PM
hzz's Avatar
hzz
I checked the packaging...it's rubber.
To Differential Front Mount
