Scratchy Cloudy Plexiglass
Old Sep 19, 2009 | 01:32 PM
itza56's Avatar
itza56
Default Scratchy Cloudy Plexiglass
Howdy, Are there any Plexiglass experts in here ?
You can see the rear window in the 56 that it is
really scratchy and cloudy, I'm sure its the original .
Is there any kind of paste or polish I should try first ?
Going to make a winter project out of this window...
All thoughts and suggestions welcome...
Thanks Dave
Old Sep 19, 2009 | 02:41 PM
mrruffhouser's Avatar
mrruffhouser
Hi Dave, You might look at some 3M products. They have a headlight restore kit that really does a great job cleaning up fogged headlights. Since the headlight lens is of similar material (I think), it should do the job. They have many products and so you might see if you can talk with a service representative to get additional advice. Good luck
Old Sep 19, 2009 | 03:07 PM
Vogie's Avatar
Vogie
Check with a aviation maintenance facility or supplier. All small aircraft windshields and windows are plastic. They have products and kits for this purpose.
Old Sep 19, 2009 | 03:26 PM
vetarun's Avatar
vetarun
vogie is absolutely correct. Its called a micromesh kit. Contains rubber block, an anti static paste, and various grits of sandpaper between about 1200 grit up to about 4000 grit. I have never used the rotary one. I have always used the manual kit sanding at 90 degree angles to the previous grit. It will look like regular glass with no scratches when your done. Try this link http://www.aircraftspruce.com/catalo...eshscratch.php
Bob
Old Sep 19, 2009 | 04:51 PM
Vogie's Avatar
Vogie
Vetarun: Enterprise = Ft Rucker. I was FW initial entry in 1970, rotorary Q in 1979, and did a tour at the Safety Center as an investigator. Moved up a bit from the C12.
Old Sep 20, 2009 | 01:10 PM
itza56's Avatar
itza56
That is Great Info... Exactly what I was looking for...
I will order ---->
MICROMESH SCRTCH REM STNDRD KT 09-24700 $24.85
the first thing monday morning..
and I'll report back as to how it worked out...
I'll even do some before/ after pic's...
can't wait to be able to see backing up..
Thanks guys.. !!
Old Sep 20, 2009 | 01:44 PM
vetarun's Avatar
vetarun
yes Enterprise = Fort Rucker. I'm retired now but my wife is still in. We were assigned to Ft Campbell. Getting out of so many rotations for a couple of years. Time for a quick break.
The micromesh kit may say to do it dry but keep water running over the pad for safer results.
Old Sep 20, 2009 | 03:08 PM
JohnZ's Avatar
JohnZ
I've used the two-step Meguiar's product made specifically for plexiglas with excellent results, and your local airport shop will have "Novus" products that also work very well.
Old Sep 20, 2009 | 04:19 PM
VetteRed1965's Avatar
VetteRed1965
http://www.aircraftspruce.com/catalo...scratchoff.php
Old Sep 20, 2009 | 04:27 PM
VetteRed1965
I always used aeroshell plexicoat on my planes.I would start with
simple pledge to remove all dirt and grime then polish out with the plexicoat.
Least advasive first.They sctratch very easy.
Heres another one. http://www.aircraftspruce.com/catalo...scratchoff.php
To Scratchy Cloudy Plexiglass
