Want to know if anybody knows Vin #s for corvettes built on
June 20 1963.I know its a long shot but you never know till you ask.
Thanks for any help you can give me. Paul
Paul, mine has a build date of June 19, 1963. VIN 117709
According to the NCRS Spec Guide 63 model year for the month of June the VIN started with #116410 & ended June #118524. Using the birthday calculator on the C 2 Registry could then calculate the June 20 VIN range.
Thanks so much!!I do appreciate the welcomes and help on the numbers.
Now to find a coupe built on that day...looking for a non nubers car.
Welcome.
Really? You hope to find a car built on a specific day, but only if it isn't numbers matching?
Good luck!
Also, understand that the various calculators predict when a car likely rolled off the assembly line, but other than end-of-month production VIN data (which is used to extrapolate likely VINs by day) there are no records that confirm specific VINs to specific days.
