Ignition problem
Old Sep 30, 2009 | 11:11 AM
VetteJohn's Avatar
VetteJohn
Default Ignition problem
I have a problem with the '66 I purchased in May. The car has had a high speed miss that I figured I could correct with normal tune up fixes. I've since changed the coil, rotor, cap, plugs and I've checked the plug wires with an ohm meter and they are fine. You'll notice that I didn't mention anything about points since this car has TI ignition. The ignition coil I installed was for a TI system and I've double checked the resistance of the coil and it is correct. I pulled the amp apart and it has the new updated electronics and the pick up coil checks out good too.
None of these actions has improved the problem. The car runs great up to 3,000 to 3,500 RPMs and then starts breaking up. Anyone got any ideas?
Old Sep 30, 2009 | 11:16 AM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Are you sure it's ignition, could be carb related. Dennis
Old Sep 30, 2009 | 11:54 AM
VetteJohn's Avatar
VetteJohn
Default Carb
I guess I got hung up on the ignition and didn't think about the carb. I start looking at the fuel system this weekend.
JP
Old Sep 30, 2009 | 12:44 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
I would check the side play in the dist shaft top end. I had the same problem with dwell fluctuation at high rpm. Good luck.
Old Sep 30, 2009 | 04:28 PM
tmpugel's Avatar
tmpugel
My dist shaft top end had excessive wear thus excessive side play. But mine would miss intermitantly at any rpm. The mechanic replaced the shaft and the problem went away.
1963 327/300
Tom
Old Sep 30, 2009 | 05:08 PM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
2015 C3 of Year Finalist
Check your float bowl levels. You may be running out of gas.
Old Sep 30, 2009 | 08:44 PM
StingU2's Avatar
StingU2
VetteJohn
... I would say that your problem is in the carb, check your float levels.
Old Sep 30, 2009 | 10:56 PM
67L36Driver's Avatar
67L36Driver
One of the few times that a carb problem is not actually ignition related.
Dist. shaft side play only effects points not usually TI setups.
Old Oct 1, 2009 | 07:43 AM
VetteJohn's Avatar
VetteJohn
Default Thanks for the help.
Thanks to everyone for you input. I'll jump on this over the weekend and see when it leads and report back.
JP
Old Oct 1, 2009 | 02:04 PM
67vetteal's Avatar
67vetteal
Hi John, You mentioned TI. What type of Dist. etc.? Al W.
Old Oct 1, 2009 | 04:54 PM
VetteJohn's Avatar
VetteJohn
Default Gm
The ignition system on my '66 is the optional system that was offered in the mid 60s on Vettes. It has a distributor with a magnetic pick up that generators a pulse that's sent to the amp. The amp increases the amplitude of the signal and sends it to the coil and from there the system works are normal. This system was call a Transistorized Ignigtion (TI).
JP
Old Oct 1, 2009 | 05:14 PM
Dan Hampton's Avatar
Dan Hampton
2018 C1 of Year Finalist
If you have a single point distributor laying around, swap that in and give it a try. At least it will only take five minutes to figure out if your problem is in the distributor.
Old Oct 2, 2009 | 08:03 AM
VetteJohn's Avatar
VetteJohn
Default I do!
Dan,
I do have a spare distributor, coil, and ballast resistor laying around. If I get sometime this weekend it's one of the things I plan on trying. Biggest problem is getting time freed up, fall around here is a busy time, over seeding and hedge trimming are on the adjenda this weekend.
JP
Old Oct 2, 2009 | 10:19 AM
gphil460's Avatar
gphil460
I had a similar an high speed "engine miss" problem on my 245hp '57. It turned out that the carbs were jetted way too rich. After replacing the metering rods and jets w/ correct ones, the car ran fine. As an fyi, the previous owner had paid large $'s to have the carbs rebuilt by a professional rebuilder in in FL and for some reason they had installed the wrong metering rods and jets (they weren't even close).
Gerry
Old Oct 2, 2009 | 10:27 AM
garth64's Avatar
garth64
You're not running too cold a plug are you?
Old Oct 2, 2009 | 10:35 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
All of the above are good suggestions....my carbs originally had the wrong needle valves and seats too...in my case the super-rich condition resulted in poor running across the RPM band and was most noticeable by the sooty, black crud on the spark plugs. This same indication would be apparent on too cold of a plug in most cases..
Old Oct 2, 2009 | 01:11 PM
mayordaly's Avatar
mayordaly
You said Higher RPM's,
More missing under acceleration or just cruising at Higher RPM?
Ever happen when foot not on gas pedal?
More when cornering? then straight aways?
Any one plug look wet or different then others after a hi RPM run?
Is there ever a backfire?
is there a "cough" or sputter? or just a short misfire?
There are a lot of things it could be. Even more then stated above
Old Oct 2, 2009 | 02:09 PM
VetteJohn's Avatar
VetteJohn
Default Answers
Originally Posted by mayordaly
You said Higher RPM's, (3200 RPM)
More missing under acceleration or just cruising at Higher RPM? Hard or light acceleration it doesn't seem to matter .
Ever happen when foot not on gas pedal? No
More when cornering? then straight aways? Never tried it.
Any one plug look wet or different then others after a hi RPM run? No
Is there ever a backfire? Nois there a "cough" or sputter? or just a short misfire? Just a misfire (I think).
Thanks,
JP
To Ignition problem
