PCV question
Old Sep 30, 2009 | 10:29 PM
GEM '62's Avatar
GEM '62
Default PCV question
I have a 300HP 327 with the road draft tube and also an oil filler tube in the front of the engine with a breather cap. Can I run a hose from the road draft connection at the rear of the engine with an inline PC valve to the vaccum connection at the carb? Will this work or is it not the correct approch?
Old Sep 30, 2009 | 10:32 PM
62Jeff's Avatar
62Jeff
If you have an AIM, take a look in the back at RPO 242. This option (required in California at the time) replaced the road draft tube with a fitting to which you connect a rubber hose. On the other end of the hose is a PCV which threads into a brass fitting, which in turn threads into another brass fitting, which finally threads into the back of the carburetor.
You can buy all of the parts you need from Paragon if you want to do it the easy way. Alternatively I understand from MikeM that the fitting that goes in place of the road draft tube was used on millions of generic 327 Chevy's back in the day, and I'm sure the brass fittings are likely available at any well stocked auto store.
Jeff
Old Oct 2, 2009 | 01:24 PM
cefolar's Avatar
cefolar
One step further from 62Jeffs post is what I did on the 327 in my '61. The hole in the back of the block is the perfect size for a standard valve cover PCV grommet. Put the grommet in the hole - push in a regular valve cover PCV valve (or a chrome one if your picky) and run a hose to the fitting on the base of the carb.
Old Oct 2, 2009 | 02:20 PM
rustylugnuts's Avatar
rustylugnuts
Thats a 'great' idea, but the check valve that is already incorporated in the PCV is not needed when replacing the draft tube as previously stated for using the (California ventilation system) do to the ventilation can that is present at the rear of the block underneath the intake manifold. Just run a 7/16" hose from the CVS to the rear of the carb and your done. An alternative method is installing a PVC valve into one on of the valve covers and running a 7/16" hose to the rear base of the carb. Either way it's a positive way to evacuate fumes from inside your engine.
rustylugnuts
Old Oct 2, 2009 | 04:37 PM
JohnZ's Avatar
JohnZ
If you make that direct connection from the vent hole in the back of the block to the carb base without either a PCV valve or the special fitting with an .090" metering orifice in it, you'll have a gigantic vacuum leak. All the can in the lifter valley does is to keep liquid oil out of the vent system - it only passes vapors.
Old Oct 3, 2009 | 06:53 AM
GEM '62's Avatar
GEM '62
Thanks for the help guys, I appreciate it.
Old Oct 3, 2009 | 09:30 AM
rustylugnuts
You are correct, my bad. Thanks John, I stand corrected.
rustylugnuts
Old Oct 4, 2009 | 01:34 AM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
Does the 242 system use a breather oil cap on the filler tube or a sealed one, my 242 cal system had been Bubba'd.
Old Oct 4, 2009 | 09:15 AM
rustylugnuts
As I can remember, the breather oil cap was originally used on hydraulic lifters, and the non-breather oil cap was used on solid lifters engines. I cannot recall them having any correlation on the RPO 242 option. My 61 has non-breather oil cap and the engine has solid lifters 283/315 FI, and also has RPO 242 without rear oil draft tube, it has a rubber hose running from rear 90 degree fitting (rear top of block) to a PVC or check valve attaching to a split T fitting, the adjacent side running to the vacuum can for the windshield washers, and the main runs directly into the left rear side of the plenum. Do to all oil caps having loose fit on the oil fill tube, I assume this would be enough air adding to the vacuum efficiency of the RPO 242 option. Hope this helped.
rustylugnuts
To PCV question
