When I built the motor for my car a few years ago, I turned the NOM 327/300 into a 327/365.
The car has not had as much power as I thought it should have, so I put it on a chassis dyno a few months ago and could only get 190 rwhp out of it.
In the last couple of weeks, I've been putting a lot of effort into getting it to run better, including a complete distributor rebuild with a correct main shaft.
I've always had the initial timing set at 10* btdc. Last weekend I started bumping the timing up a few degrees at a time and taking a test drive.
What I have ended up with so far is 15* initial, all in (about 40*, vacuum can disconnected) at 2800 rpm. The car is much more "peppy". Feels like it could still use more timing.
Since these numbers don't seem to make much sense, I'm thinking I have the correct timing cover, but have the the wrong 8" balancer (newer than '69 style). When the weather clears, I'm going to try about 20* initial. If I don't get any detonation, then I'll pull the #1 plug and see where TDC really is.
They make a tool for this that you insert in the #1 spark plug hole, you take out all the other plugs and rotate the motor by hand, fore and back and mark the two stop points in the balancer, exactly halfway in between is TDC. That should correspond to the mark on the balancer.
You do have 11:1 comp pistons for that cam, right? Are you sure the cam is indexed correctly? A dial indicator on #1 intake vs the cam card will tell you that.
You answered your own question, physically find TDC of #1, check markers. In the past I have taken degree tape and put on the hormonic THAN with a punch permanatly mark TDC, 5 deg., 10 deg., and so on. The tape will eventually "fly off".
Thoughts?
you could have the right balancer with the wrong timing tag....this will render a timing light useless....keep doing what you are ie..run the advence up and feel it with the seat of your pants in all driving conditions..if you get a ping..you went to far...the vac can is another issue wheather to use it or not...if you do want it in the system then leave it hooked while doing your road tests..good luck....
The correct balancer for a Corvette application has the timing index line on the inertia ring directly in line with the keyway slot in the hub; passenger car balancers changed in 1969 by moving the index line 10* counter-clockwise from the keyway slot (and their timing cover tabs also moved the same amount). Photo below is a Camaro 8" balancer, but it shows the location of both marks.
Doug
What pistons do you have?
If you are running a 30-30 cam with Flat top Pistons, your engine will run very flat. Adding more timimg will help a little but that is just masking the problem of not enough compression.
Question for John...
Page 38 of the Chevy Power book, Seventh Edition, 2/94, says that the pre-69 balancers had the TDC mark 2 degrees advanced (CCW from the keyway), and that later balancers moved the TDC mark 10 degrees advanced (CCW) from the keyway. So, which is correct for pre-69 alignment - 2 deg CCW or in line with the keyway? Is this an error in the Chevy Power book?
If you are running a 30-30 cam with Flat top Pistons, your engine will run very flat. Adding more timimg will help a little but that is just masking the problem of not enough compression. Chris, CWPASADENA
Not 11:1, but a calculated 10.65:1. Also running the 70 LT-1 cam instead of the 30-30.
The stock ignition curve for 327-365 is the most aggressive curve that GM specified.
Start @ 800 RPM
15* @ 1600 RPM
24* @ 2300 RPM
You could probably bring your curve in faster w. detonation the limiting factor. Start w. an initial timing of 12* and bump higher till you run into knocking. This will increase your low end torque. Use a B 28 VAC for good idle and control of excess EGT. Also use HD points ( BWD 112 hp) and a non emissions rotor & cap.
Yup, it's an error, and has been carried forward in all manner of other books; the GM drawing (below) of the balancer makes it quite clear that the index line is exactly in line with the keyway, +/- 1/4 of a degree (see note at top left).
