427 ID help?
Old Oct 6, 2009 | 09:00 PM
mjdwyer23's Avatar
mjdwyer23
2nd Gear
Default 427 ID help?
Hi Folks-
I'm hoping the Vette community can help me out identifying the motor in my 70 chevelle. The previous owner says it's a 427 -- I have a casting number of 3963512 from the back of the engine. What other numbers do I need to ID this motor? The vin pad is clean except for a 7 -- block might have been decked. Thanks!
MD
Old Oct 6, 2009 | 09:57 PM
provette67's Avatar
provette67
the 512 block was used as both a 427 in 1969 and a 454 in 1970.What is the date on the block?
Old Oct 6, 2009 | 10:03 PM
knight37128's Avatar
knight37128
Look to see if there is a weight on the harmonic balancer or the flywheel.
The harmonic balancer weight will be on the inside of it (you will have to feel it).
If there is a weight it is a 454, if not a 427.
Old Oct 6, 2009 | 10:34 PM
mjdwyer23's Avatar
mjdwyer23
2nd Gear
Looks like the date on the back says E 18 70 -- 1970 454? Thanks guys!
Old Oct 6, 2009 | 10:45 PM
67L36Driver's Avatar
67L36Driver
But.................................That is just the block.
Check for the counterweight anyway.
Old Nov 10, 2009 | 07:52 PM
copo9560's Avatar
copo9560
I agree - check the balancer. I have a CE 427 in my old Camaro - was assembled in 1970 as a warranty replacement short block.
Old Nov 11, 2009 | 12:10 PM
JohnZ's Avatar
JohnZ
Here's what the back side of a 454 balancer looks like - note the cast-in weight.
To 427 ID help?
