Muncie ID Help
Old Oct 15, 2009 | 07:44 PM
jtranger's Avatar
jtranger
Default Muncie ID Help
I currently have a '63 Muncie in my '65. I found a Muncie for sale locally that has the correct casting 3851325 and tailshaft 3857582. The input shaft number is 3952648 and cover number is 39105020. The trans has a 6 cyl bellhousing and was in a '64 truck. Will this work with my '65 with the different input shaft number? I can just change the side cover,correct? Regards, Larry
Old Oct 15, 2009 | 10:01 PM
jtranger's Avatar
jtranger
Ttt
Old Oct 16, 2009 | 01:24 PM
jtranger's Avatar
jtranger
Ttt Anyone
Old Oct 16, 2009 | 01:26 PM
MiguelsC2's Avatar
MiguelsC2
St. Jude Donor '10-'12-'13
Ttt??
Old Oct 16, 2009 | 01:30 PM
jtranger's Avatar
jtranger
Take it To the Top = I still need help!
Old Oct 16, 2009 | 01:31 PM
JohnZ's Avatar
JohnZ
Which bellhousing do you have?
Old Oct 16, 2009 | 01:48 PM
jtranger's Avatar
jtranger
Hi John, Thanks for chiming in. Not sure what bellhousing is on the car with the '63 trans. I heard the '63 Muncie and bellhousing were unique to that year. I was planning on just getting a '65 bellhousing to go with the 3851325 trans. I noticed the input shaft number was different on the one I wanted to buy. I didn't want to buy the trans unless it will work. The trans is priced reasonably so I wanted to buy it if it will work. Larry
Old Oct 16, 2009 | 03:44 PM
JohnZ's Avatar
JohnZ
That's why I asked - the '63 T-10 and Muncie both had a one-year-only small-diameter front bearing retainer, and a one-year-only 421 bellhousing with a smaller hole for it.
403 bellhousings are plentiful and not expensive - you'll need one.
Do you mean input shaft number, or front bearing retainer casting number?
Old Oct 16, 2009 | 04:00 PM
jtranger's Avatar
jtranger
John, Front bearing retainer casting number number. That's what I meant! I have an appointment to look at it tomorrow. Will it work with the 403 bellhousing? If so I will buy it.
Old Oct 16, 2009 | 04:34 PM
JohnZ's Avatar
JohnZ
You have the numbers reversed - 3952648 is a side cover (used from '70-up), and 3915020 is the front bearing retainer (used from '68-up).
The main case (3851325) was used in '64-'65, and the tailhousing (3857584) was used from '65-up.
It's kind of a mix-and-match, but it'll work with a 403 bellhousing.
Old Oct 16, 2009 | 04:47 PM
jtranger's Avatar
jtranger
John, I plan to change the side cover to the correct 3831707. So, the only thing that won't match is the bearing retainer casting number. As Always thanks John!
To Muncie ID Help
