Are there any differences....any differences at all.....between the 67 427/435 TRI POWER carbs I have.....and 68 or 69 427/435 TRI POWER carbs....thanks for the help.
The front and rear carbs are all the same for 67-8-9 435's, but the center carbs are different; 67's used R3660A (3902355), and '68 used R4055A (3925517) early and R4055-1A (3940929) late, and '69 also used the R4055-1A.
John, I hope I am not wearing you out here? What physical differences were there on the later center carbs?
Thank you for taking the time to post a reply. I'm sorry I was not more clear.....aside from the numbers difference....of which I was aware, and which was the reason for my question....are there any physical differences in the 67, 68 and 69 center carbs of 435 horse Corvette carbs....thanks for the help.
Up until a few months ago I had 3 complete sets with intakes and a extra new center carb....They all looked the same to me except the date codes but each set matching each other....The new one is a Holley replacement carb and I presume without the GM numbers and letters on the air horn...its still in its Holley box for L71`s
I very much appreciate your taking the time to provide this information. Would you think it worthwhile to modify the 67 center carb to the specs of the 69 center carb? Thanks again for the help.
