Teflon tape?
Old Feb 24, 2002 | 10:00 PM
JPatrick's Avatar
JPatrick
Default Teflon tape?
I did a fuel pump install a few days ago and I now find I want to make a change to the fuel line routing. When I picked up the 90 degree fitting, I needed I asked the guy at the parts counter if there was anything I should coat the threads with. ( I have never used anything, but times change so I always ask) He said it woudn't hurt to use some tape on it. I asked if he meant teflon tape and he said yes. Well I use lots of this mainly for keeping the sprinkler system going, but it seems like this stuff would not mix with gas. What do you guys think?
Old Feb 24, 2002 | 10:08 PM
JohnZ's Avatar
JohnZ
Default Re: Teflon tape? (JPatrick)
I don't like Teflon tape, as it can shred and let little particles into the fuel filters, etc. I prefer the TFE (Teflon) pipe joint paste, applied sparingly, to keep the pipe threads from galling and so you can disassemble it later if you have to. Works for me.
Old Feb 24, 2002 | 10:15 PM
JPatrick's Avatar
JPatrick
Default Re: Teflon tape? (JohnZ)
Where would I find that stuff? Kind of sounds like a home depot item.
Old Feb 24, 2002 | 10:27 PM
JohnZ's Avatar
JohnZ
Any hardware store, in the plumbing section - TFE pipe dope.
Old Feb 24, 2002 | 10:59 PM
62fuelie's Avatar
62fuelie
I agree with John. Don't use the teflon tape. Any sort of "pipe dope", be ti teflon or otherwise, serves to lubricate the threads so that the fitting can be properly tightened. The fittings are tapered and seal by thread interference. The "pipe dope" is NOT a sealing agent. It does help in tightening and eventually loosening.
Old Feb 24, 2002 | 11:11 PM
JPatrick's Avatar
JPatrick
Default Re: Teflon tape? (62fuelie)
Speaking of proper tightening, when I install that 90 degree fitting it can point in only one direction to work. If this thing happens to get tight when it is 3/4 of a turn away from where I need it am I safe in really turning on the power in order to get it swung around where it should be?
Old Feb 24, 2002 | 11:45 PM
62fuelie's Avatar
62fuelie
If your fuel pump is the type with the steel fittings sticking out the bottom, you can probably crank it with the steel fitting properly supported in a vise. If it is the type with the fittings in a cast housing, be careful. Depending on how tight it is 3/4 of a turn away, I might back it up a quarter turn.
Old Feb 24, 2002 | 11:58 PM
JPatrick's Avatar
JPatrick
The fitting is actually in the housing so I'll have to be careful how much I give it. I would hope that the add on fitting would be designed to strip before it could do damage to the pump, but it probably isn't. With a little luck it may line up perfectly (sure).
Thanks for your help
Old Feb 25, 2002 | 08:17 AM
Kid_Again's Avatar
Kid_Again
...on fuel lines, i've also used a teflon-containing white sealant that's in the same aisle as loc-tite (it may actually be mfg'd by loc-tite)...works well and said to be used by the factory on c5's - wouldn't know.............
Old Feb 25, 2002 | 10:23 AM
anselboyce's Avatar
anselboyce
Default Re: Teflon tape? (Kid_Again)
Here is the stuff you want, Thread Sealant with Teflon by Permatex. It comes in a 1 oz. tube and is about 5 inches long. It can be found at any auto supply house, Pep Boys, AutoZone, etc.
Old Feb 25, 2002 | 10:53 AM
Daren Schneider's Avatar
Daren Schneider
I was told that teflon tape was for Shxxhouses and do not use for fuel lines.
The fuel lines are compression fittings and do not need teflon tape. I was a big teflon tape junkie until I was converted from a well know Carb builder in Missouri. :smash:
Old Feb 25, 2002 | 01:59 PM
JohnZ's Avatar
JohnZ
Default Re: Teflon tape? (Daren Schneider)
The TFE pipe dope is also useful for the usual SAE flare fuel line fittings; not for the flare, which is where the seal is, but to lubricate the straight steel-on-steel fitting threads so they don't gall. Takes less torque to get a good mechanical seal at the flare due to reduced thread friction, and they can be disassembled later without damage. A little anti-seize would probably work just as well.
Old Feb 25, 2002 | 03:40 PM
Kid_Again's Avatar
Kid_Again
...i even put a bit of antisieze on retaining nuts for the brake hardlines...you have to be REAL careful on that but i've had no problems at all - now, if i'd just figure out how to STOP removing the brake lines, i'd be in great shape :rolleyes:
Old Feb 27, 2002 | 06:12 PM
mikes64's Avatar
mikes64
Default Re: Teflon tape? (anselboyce)
Anselboyce:
The pictures of your car are awsome. I was noticing that the frame
seemed to be very good condition or have you restored it also. I could
not tell if you had a body off or just conditioned the frame with the body on.
Looks very nice. Any help you could give would be appreciated. I have a 64
coupe and the front end and rear have been completely gone through before
I purchesed the car, however, I would like to detail the frame without removing the body.
thanks,
Mike
Old Mar 1, 2002 | 10:15 AM
anselboyce's Avatar
anselboyce
Default Re: Teflon tape? (mikes64)
Mike - thanks for the nice comments. No, I did not remove the body from the frame. Before I got the car it had sat untouched in a garage for 22 years. The frame was in good shape and all I had to do was clean it. The original owner striped off the paint in '79 and also striped the car down to body and frame. The engine was not original so I decieded to do it my way. As soon as my new hood arrives it is off to the body shop for paint.
To Teflon tape?
