Horn button sticking???
Old Oct 18, 2009 | 08:45 PM
jlagarde's Avatar
jlagarde
Default Horn button sticking???
I've looked through alot of threads about horn problems but none seem to deal with the button sticking or continuing contact to after release.
It seems when I tighten the 2 screws and post the button won't disconnect. I don't mind getting a new one but it would be a drag if it turns out to be something else.
Any ideas on what I could be doing wrong or other suspects?
Thanks for any help.
Go Saints!!
Joe
Old Oct 18, 2009 | 08:47 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
its most likely the horn contact ring under the button.
Old Oct 18, 2009 | 09:00 PM
62Jeff's Avatar
62Jeff
Do you have the correct horn contact? The wrong contact has a longer leg that touches the brush which makes the horn circuit. If you have the longer contact in place, it is possible that the horn is trying to be on all the time. I'm particularly suspicious since you indicate it happens as you tighten down the screws.
What year are you working on?
I had a similar problem with my 65, although it manifested itself in the horn going off in turns.
Here's a photo of the incorrect (left), and correct (right) contact. Note the difference in the leg.
Old Oct 18, 2009 | 10:07 PM
jlagarde's Avatar
jlagarde
I saw your photo earlier when I was searching.
I should have been more forthcoming - I have a 66 telescopic and I don't have the leg. I don't know enough to say I should have one but I'm pretty sure mine wouldn't use that configuration as I can't see where the leg would go.
Joe
Old Oct 18, 2009 | 10:17 PM
62Jeff's Avatar
62Jeff
Joe
Ok, yes that data would have been better
You can ignore my post, it doesn't apply to tele columns.
Old Oct 18, 2009 | 10:45 PM
jlagarde's Avatar
jlagarde
It should have been a "Joe Friday" post.
Thanks for the reply.
Joe
Old Oct 18, 2009 | 10:50 PM
jlagarde's Avatar
jlagarde
I have everything out except the contact assembly. Which piece of the assembly is the ring?
To Horn button sticking???
